Results 1 to 10 of 10
This is a discussion on 2002 wrx misfire on cly 1&2 above 4500 rpm within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; 2002 wrx 2.0 turbo misfiring on cly 1&2 above 4500 rpms. already changed intake tube by the turbo spark plugs ...
    Nov 2012
    Exclamation 2002 wrx misfire on cly 1&2 above 4500 rpm
    2002 wrx 2.0 turbo misfiring on cly 1&2 above 4500 rpms. already changed intake tube by the turbo spark plugs timing belt and MAF unable to find any boost leaks.
    compression is good spark is good and timing is good. fuel pressure is fine. if you unplug the MAF to make it run super rich it runs fine. any ideas?
    Jan 2012
    Philly Area
    - William
    Nov 2012
    ive already read and tested everything in that thread.
    Mt. Laurel, NJ
    Ok I got it...finally. This will fix it.
    Buy a new car.
    Nov 2012
    lol not my car
    Jan 2012
    Philly Area
    MAF put back in facing the wrong way? It has been known to happen. Frequently.
    - William
    Moderator Donkey's Avatar
    Da boonies
    Quote Originally Posted by Kyle.G View Post
    I seriously doubt that.
    2002 FORESTER S
    1998 FORESTER S
    Nov 2012
    and why do you "seriously doubt that"? ive been a mechanic for 13 years i know how to diag a car just so u know. no need to be a jerk
    Da boonies
    You checked the valve clearances? Leakdown test? I said what I said because 99% of the people that claim they "did everything" ended up doing just about half of the list. Checking the valve clearances is a PITA with the motor in car on a Subaru and even harder to change the shims. Hence why most people skip that along with moving injectors.
    2002 FORESTER S
    1998 FORESTER S
    Nov 2012
    problem solved it was the aftermarket cold air intake made by AEM
