Results 1 to 15 of 17
This is a discussion on Maintenance Time. within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; So, I hit 30k miles, and after doing research I see its suggested I change transmission fluid. My question is, ...
    Registered User Mike193's Avatar
    Nov 2011
    North Jersey
    Maintenance Time.
    My question is, is this a project I should easily be able to tackle myself, or should I bring it to a shop.
    Maintenance Time.
    It's required, not suggested. There are DIY how-to threads about. If you DIY use the correct spec geal oil, buy a factory washer for the drain in the gear box, consider a silicone sealant for the rear diff plug, and keep ALL dated receipts. See DIY thread.
    Registered User speedtown's Avatar
    Feb 2012
    VT
    it's seriously required at 30k? if didn't have the warranty still I'd def push it off. Well at least it's a good time to upgrade the fluid. Of course I'm going to hit 30k in the middle of winter, just great!
    Maintenance Time.
    Check your manual to be sure of the interval. Mine has "R" not "I".
    Registered User shadowpr's Avatar
    Jan 2011
    TX, NY
    it's easy to do. just buy some subaru trans fluid (extra-s)
    i ddin't notice a washer on mine, but i used some gasket sealer on the threads for both the trans and rear diff.
    i suggest you buy a length of clear hose to do the rear diff, and have someone there to help you pour it in while you hold the hose in the hole. and go slow.
    the trans itself is really easy. easier than an oil change.
    you will need a t-70 socket though.
    One thing that can't be overemphasized I think is, when doing the rear diff, remove the FILL bolt first. DO NOT REMOVE THE DRAIN BOLT FIRST.
    May 2010
    Pittsburgh, PA
    Is this in case the top bolt is stuck or for venting reasons?
    2011 STi Build Log
    Quote Originally Posted by Heide264
    So you don't get stuck with an empty diff, unable to refill it.
    May 2010
    Pittsburgh, PA
    Yup... so to make sure the bolt isn't stuck. That would be frustrating.
    2011 STi Build Log
    Moderator   Sasquatch's Avatar
    Apr 2004
    Southeastern PA
    Oh. Never did that. Great advice.
    I was always able to get both off rather easily.
    Moderator for: Aftermarket Vendor & Installer Review / Detailing Forum / Engine Modifications / Exterior & Appearance
    New Member Hangout / Off Topic / Tri-State
    Mods & Pics
    Quote Originally Posted by Sasquatch
    :giggity:
    Not everyone has Bigfoot strength.
    Apr 2004
    Southeastern PA
    :giggle: at :giggity:
    A 22" breaker bar makes it easy enough.
    Mods & Pics
    Oct 2011
    Santa Ana, CA
    A 22" breaker bar almost rounded my top bolt =(
    Where that is insufficient, add a jack handle to the mix.
    Yes it's so you don't end up with an immobile car and a stuck fill bolt. Sure it's 1:1000 that'll happen, but there's always that 1000th time and I don't want to be a statistic.
