Results 1 to 15 of 19
This is a discussion on Subaru is baffled, as am I. Please help within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; This part was leaking power steering fluid so i took it off to replace. Well I go to Subaru and ...
    Apr 2011
    Watertown, New York
    This part was leaking power steering fluid so i took it off to replace. Well I go to Subaru and they dont have any idea as to what it is because the part diagrams they use dont show this part as being there. Rather, they show that instead of this line being connected to a hose they show that it is one solid line but trust me thats not right. They asked their techs as well and they dont have any idea, therefore i am on my own and could use the help.
    I know its not the return line because there is pressure in the line when the car is on. I know that it is located under the car on the drivers side near the rack. Seemed like this was going to be an easy fix but i cant find the part to save my life. Please help lol
    Negative pantsy rage-wrx's Avatar
    Aug 2010
    Yonkers/NYC
    Why not have it looked at & replaced under warranty?
    -Tony
    2011 WRX WRB Stage2
    2012 FXT DGM
    The Big 2011/2012 Mod Thread
    "Just Leave me alone. I know what I'm doing"-
    Kimi Räikkönen
    Apr 2011
    Watertown, New York
    I dont have a warranty. wish i did I have been doing all my own work on this car because Subaru wont touch it due to them not being able to gurantee their work. This is because its modded
    Aug 2010
    Yonkers/NYC
    You can upload pics to Photobucket & paste the url. Post as many pics as you want.
    Have you tried to take it in to the dealer. There shouldn't be a reason for denial. I know of at least one member who had a power steering fluid leak fixed under warranty on his Stage 2 car.
    -Tony
    2011 WRX WRB Stage2
    2012 FXT DGM
    Kimi Räikkönen
    Apr 2011
    Watertown, New York
    Yeah I thought so too but the dealership out here wont touch it and they guy i bought it from bought the car in Cali and in in NY. Subarus guys think that the line is one solid line, which when i took it off there was the piece in the pic, connected to a hose, then another piece like in the pic on the other side. These were clamped down and that was it. Looking at the subaru diagram there is no hoses at all down there, I dont want to buy a part that dont fit because the return policy here is ridiculous. Hands are tied
    Registered User Kwrxp's Avatar
    Aug 2012
    Spring Grove, PA
    They can't deny your warranty because of modification, they can deny warranty work that is directly caused by a modified part though. Take it to another dealer, my power steering is leaking too. Theyre repairing it even though I'm modified and purchased it from VA.
    '11 WRX DGM
    Apr 2011
    Watertown, New York
    Quote Originally Posted by Kwrxp View Post
    Ya ill have to try and go down to Syracuse then i suppose. I was looking at the pics i got and it might be able to be replaced by the power steering high pressure hose #22 on the diagram on subaru.com. I just need to find someone else that has done it so that i KNOW its the right part.
    Aug 2010
    Yonkers/NYC
    The only related thread on the issue. Doesn't look like the leak is in the same spot though. I don't see Part #22
    Anyone know anything about the steering valve assemby?
    -Tony
    2011 WRX WRB Stage2
    2012 FXT DGM
    Kimi Räikkönen
    Apr 2011
    Watertown, New York
    Quote Originally Posted by rage-wrx View Post
    If you go to subaru.com and then steering for a 2005 wrx. Once you get there and go to the second set of diagrams, youll see #22. I was looking at the pic i have and it disconnects on both ends, therefore #22 being the pressure pipe its the only one that seems long enough to be it. Plus, when i noticed the leak it was spraying so i know i had pressure. The return pipe doesnt have any pressure.
    Apr 2011
    Watertown, New York
    Haha now im confused tho because the diagram you showed me could have the part i need too. Darn it
    Aug 2010
    Yonkers/NYC
    Re: Subaru is baffled, as am I. Please help
    Ah my bad for thinking you had a newer model. The 13 in your user name was misleading,lol.
    -Tony
    2011 WRX WRB Stage2
    2012 FXT DGM
    Kimi Räikkönen
    Registered User jeremydingeman's Avatar
    Mar 2012
    Bothell, WA
    As a plumber i would say just get a couple 3/8 compression couplings and a piece of 3/8 soft copper and replace the piece of pipe that has a leak in it.
    Find a low-mileage one-owner unmodified '04/'05 and you're golden.
    Understeer is when you hit the wall with the front of the car.
    Oversteer is when you hit the wall with the rear of the car.
    Horsepower is how fast you hit the wall.
    Torque is how far you take the wall with you.
    Apr 2011
    Watertown, New York
    Haha that would be nice lol. So when using photobucket which url do i use so that you can see these photos
    Apr 2011
    Watertown, New York
    Quote Originally Posted by jeremydingeman View Post
    As you can see in the pic, the guy before me tried to go a route similair to the one you have by brazing the metal and it lasted awhile but failed eventually. Therefore ima have to figure this out and get the part designed for the car.
    Apr 2011
    Watertown, New York
    http://i1342.photobucket.com/albums/o773/Kcanfield13/imagejpeg_2_2.jpg
    http://i1342.photobucket.com/albums/o773/Kcanfield13/imagejpeg_2_3.jpg
    These are the photos of the two sides that im talking about. the Hose was connected to the part you see in the first photo on the original post. Where you can see the threads is where it goes in and then you have the other side that can also be disconnected.
