Results 1 to 8 of 8
This is a discussion on Coolant bleeding within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Just put in an aluminum radiator and a thermostat. Trying to get the damn thing to bleed and it just ...
    Apr 2012
    A, A
    Coolant bleeding
    Just put in an aluminum radiator and a thermostat. Trying to get the damn thing to bleed and it just wot get heat and it keeps getting hot any suggestions?
    Coolant bleeding
    Search "burp the system"
    Apr 2012
    A, A
    I've read the threads they don't help my situation
    Coolant bleeding
    Is there circulation?
    Apr 2012
    A, A
    Not in the lower hose it won't get warm so I thought it was my t stat but that didn't fix it and all I did was change the radiator never overheated or anything.
    Coolant bleeding
    Have you burped the system?
    Apr 2012
    A, A
    That's what I'm trying to do.
    Coolant bleeding
    How are you going about it? I'd try like this but STAY AWAY from the fans. They can come on any time!
    http://www.clubwrx.net/forums/2954530-post.html
    Careful.
