Is this a normal TURBO sound? Video/Sound
Results 1 to 15 of 15
This is a discussion on Is this a normal TURBO sound? Video/Sound within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I have an appointment to see Subaru about several issues regarding my STOCK 12 WRX hatch w/ almost 15K miles ...
    Registered User CaQuin's Avatar
    Jan 2012
    Queens, NY
    I have an appointment to see Subaru about several issues regarding my STOCK 12 WRX hatch w/ almost 15K miles this Wednesday. Issues with a possible throw out bearing (faint rattling noise when clutch disengaged on neutral), sounds of a squilling belt when clutch engaged on neutral and when changing gears (faint sound, only when the car is cold - goes away when warm), noisy shifter or trunk (creaking/squeeky sounds), & rattling A-pillar.
    I noticed today that my turbo is louder than usual. I drive a lot of city driving were I don't get to use the turbo. When I drive on the highway, I hardly go over 70mph. Today however, I was coming home from a weekend outing and had the chance to actually drive the car. I was conservative, not exceeding 80/85mph and for only short moments. I didn't want to be wreckless and irresponsible.
    Anyways, on 5th gear, the whistle is loud when flooring/gassing it above 3200rpm. The whistle is only loud on 5th gear. I tried to see if I can hear the whistle as loud on other gears over 3200rpm, but nothing comparable. Other gears have a quieter whistle sound. Below are two videos. Should I be concerned and bring it up to the dealer or is this NORMAL and I'm being paranoid? I really don't want the dealer to push the car if they don't have to.
    1st vid of the odo. Sorry for the quality, taken with iPhone. Notice 0:03, 0:09, & 0:15.
    https://www.youtube.com/watch?v=Y2VS...s&feature=plcp
    2nd vid is on the iPhone on the iPhone holder, just to hear the sound clearer. Notice 0:04 & 0:10.
    https://www.youtube.com/watch?v=AxEv...o&feature=plcp
    Thanks in advance!
    Registered User anpato's Avatar
    Jun 2012
    Doesnt sound normal.... But im not too sure, maybe one of the other more expirienced members will chime in.
    2013 SWP WRX Sedan
    Hillside, NJ
    Invidia Catless Downpipe, Custom Short Ram Intake, Self Tuned Using ECU Flash, Romraider and Tactrix
    Registered User 11blackwrx's Avatar
    Sep 2011
    Akron, OH
    yeah i agree it doesnt sound normal, almost sounds like a leak of some sort
    2011 Subaru WRX Premium
    1988 Ford Mustang GT
    2000 Jeep Wrangler TJ
    Jun 2012
    Quote Originally Posted by CaQuin View Post
    Thanks in advance!
    Check your hose from the TMIC into the throttle body, then inspect the turbo and check to see if there are any cracks.
    2013 SWP WRX Sedan
    Hillside, NJ
    Feb 2012
    A, A
    Had the same noise,2012 sedan wrx. 10,000 miles. duct from TMIC came loose going to intake. Mine got worse in a couple days after first hearing it. 1 hour problem fixed at Subaru.
    Jan 2012
    Queens, NY
    OK thanks guys... I'll bring it up to the dealer this Wednesday.
    Jun 2012
    It happened to me haha, except my car starting back firing when coming off the throttle and would bog down in boost lol
    2013 SWP WRX Sedan
    Hillside, NJ
    Jun 2012
    Mine did the throw out bearing also, dealership wouldn't so anything because they couldn't replicate it.
    Aug 2012
    Tucson, AZ
    The A pillar is normal. There's a tsb out for it. Take it off, and put tape or teflon over the clips to fix
    Aug 2012
    Tucson, AZ
    Oh, and the throwout bearring isn't supposed to be normal but i wouold say at least 80 percent of this forums population has the same problem...for our gen wrx
    Jan 2012
    Philly Area
    Quote Originally Posted by nsibanez View Post
    I would caution against making up statistics.
    - Will
    Registered User Ingo's Avatar
    Mar 2012
    Colorado Springs, CO
    +1 : Don't trust any statistics you didn't make up yourself...
    Jan 2012
    Queens, NY
    So I got my car back today and I wanted to let you guys know what's up. Maybe you can shine some light into this as well...
    Regarding the Turbo sound... Apparently it's normal. They said at normal driving and at normal highway speeds up to 75mph all sounds fine and all is working well. Their explanation is, when you floor the car and it reaches that high of an RPM, you are putting the turbo to work; more so than a regular conservative drive. Sounded like a valid explanation. Do you guys have any objection to that?... They did look at the hosings/ducts, they said they are all intact. They tried to tighten them some more but they were already tight.
    The A-pillars are no longer rattling! I'm excited over that.
    Throw out bearing... well they couldn't duplicate what I was talking about. They said if it was the throw out bearing, you would here something else. I tried showing them but they were saying that the engine noise of the WRX are traditionally loud. Hearing more engine noise when clutch is disengaged is normal. What they were hearing was normal.
    The squeeky shifter noise... "FOUND SHIFTER MOUNT LOOSE CAUSING NOISE. REMOVE CENTER EXHAUST PIPE, REMOVE HEAT SHIELD, REMOVE HANGER BRAKET FROM TRANS. REMOVE PROPELLER SHAFT TIGHTEN BOLTS TO GEAR SHIFT / STAY TO TRANS. FROM CHASIS BUSHING SUPP. ROAD TEST TO VERIFY REPAIR." Arghhh!!! noise still there and it was louder! However, the sound seems to get lower and lower when car gets warmer and driven a good period of time. Maybe bc it's getting really cold now that more noise will appear? I guess that is another horrible noise to be added to the notorious sounds of the WRX. In a way I can deal with it as long as engine & tranny is good.
    MY12 Subaru WRX - Horrible sound! - YouTube
    They said car engine wise is good. Tranny and bearing is good. I just find it hard to believe that a car especially new can make so much noise!
    Anyways, if you guys think other wise let me know. Thanks again for all your responses and help.
    Jan 2012
    Queens, NY
    Registered User wrx1234's Avatar
    Sep 2009
    Dover DE
    hes got a %50 chance of being right.
    2009 WRX - Catted DP, Torqued performance stage 2
    2011 Sportwagon TDi
    1970 Chevy Impala Convertible 454
