It is in the passenger kick panel. It is a green relay conector. And the factory repair manual will tell you exactly where it is.
This is a discussion on where is the fuel relay fuse on 02 WRX 2.0? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; after 10k of a cheap napa fuel filter, the thing started leaking under the cap. bought a wix from oreilly ...
after 10k of a cheap napa fuel filter, the thing started leaking under the cap. bought a wix from oreilly and last time i did it was by a youtube vid, not explaining the 1st details i got on ask.com bout opening the gas cap, disabling the fuel pump relay, run till car stall. I simply disconnected the in and out and stuff it with something to keep the fuel in! easy or no no? but this time i want to do it right, I checked my manual and it doesn't show nor any sites tells you, 1 site says its in the passenger side kick panel, but it's actaully a green and white wire, that u disconnect?
hmmm..I checked the glossary in the back for fuel relay, but i guess i must've miss it, but thanks, i'll try that
