Results 1 to 12 of 12
This is a discussion on CELL po224 11' WRX within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; My light comes on from time to time when i'm doing WOT or even mild pulls in 4th and 5th ...
    Registered User angelfox's Avatar
    Jan 2012
    Hagerstown MD
    CELL po224 11' WRX
    My light comes on from time to time when i'm doing WOT or even mild pulls in 4th and 5th gear. I've looked around and it says its fuel cut but nobody seems to have a solid answer to my problem. I'm debating on selling my car but I wouldn't sell it if it continues to do this. I've heard I need a Catted DP (Which I Have) to fix the issue due to the back pressure. I've also heard I need a vacuum hose to help. The posts I found were created many years ago and just wanted to know if something new has come to light. Thanks for the help in advance!
    -SPC Rock
    RayfieldsWRX - "You like the feel of torque steer? Interesting"
    jd92677 - "I like the idea of mashing the gas and not knowing which way the car will go."
    Mt. Laurel, NJ
    That's a code for wastegate pressure right?
    I assume you are Stage 2?
    Sounds like some creep to me. What vacuum hose would help?
    Jan 2012
    Hagerstown MD
    From what I've read it is boost creep. yes i'm stage two but some people were talking about a vacuum hose. I just wasn't sure if somebody had this issue and fixed it.
    Mt. Laurel, NJ
    I can't think of anything a vacuum hose would do.
    You running a Cobb Accessport Stage 2 map? If so, I'd load the Lower WDC map and see if that helps.
    Jan 2012
    Hagerstown MD
    I am not. I'm currently running the Torqued Performance map. I'll have to find my cable and switch maps. It's not all the time but it is happening more frequently than I'd like it to be.
    Mt. Laurel, NJ
    Quote Originally Posted by angelfox View Post
    Shoot Eric at TP a message and mention it to him. He could probably give you a new map that still performs well with an adjusted WDC value.
    You're overboosting. You need to modify the tune. Reach out to Eric, and see if he's willing to help.
    If not, I'll do it...
    Jan 2012
    Hagerstown MD
    Do either of you happen to have Eric's email? I purchased the tune months ago when I initial went stage two. Ej257, thanks for the offer to help. I see you posting everywhere and trust you, in case Eric happens to be unable to redo the map.
    Torqued Performance
    Apr 2007
    8000' up in Colorado
    What mods exactly do you have?
    Scott
    Jan 2012
    Hagerstown MD
    Just a Perrin DP & Catback. AEM Intake.
    Registered User rurso01's Avatar
    Oct 2012
    what part of hagerstown? i have a swp hatch here in htown as well
