Fuel Rails? or Check Valves?
Results 1 to 7 of 7
This is a discussion on Fuel Rails? or Check Valves? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I think my subie, 06wrx, isn't getting fuel pressure in the engine. Are there check valves in the 06 wrx? ...
    Registered User Soupa's Avatar
    Sep 2012
    Utah
    I think my subie, 06wrx, isn't getting fuel pressure in the engine. Are there check valves in the 06 wrx? (What I mean by "check valve" is a spot in the fuel line where the fuel is allowed to go one way but not the other way, sort of a one way street for fuel, so that way it keeps the pressure in the engine)
    Or is this a fuel rail problem? maybe in need of repair or replacement?
    any info is appreciated
    Jan 2005
    Eh, whaaaaa?
    How are you sure your engine isn't getting fuel?
    Cody
    Moderator Donkey's Avatar
    Da boonies,Va
    I would start by actually verifying fuel pressure and go from there. That is how you actually go about diagnosing an issue.
    2002 FORESTER S
    1998 FORESTER S
            MainFrame's Avatar
    Austin, TX
    If you ARE having fuel pressure issues (should check with a gauge), then I would suspect the fuel pump/controller/wiring. It could also be an issue with injectors.. but you haven't said what your symptoms are, so really it could be anything (honestly, probably not fuel related).
    Sep 2012
    Utah
    the car doesn't start sometimes, after i drive it for a while it doesn't start. Starts up fine when cold, but when its hot it doesn't start, only cranks, and the overly loud noise of the fuel pump leads me to think it's not pressurizing. the fuel pump should be fine because I just replaced it a few months ago. I found no shorts or blown fuses in any of the fuse boxes.
    The Hawk-Eye Alliance*eleventy,000,000,001*
    Da boonies,Va
    2002 FORESTER S
    1998 FORESTER S
    Sep 2012
    Utah
    Thanks donkey, I am going to take a look at the ground wires.
