Results 1 to 11 of 11
This is a discussion on outside temp sensor within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Can someone tell me where the outside temp sensor is located? ('12 wrx) I don't think my outside temp is ...
    Registered User free2be4ever7's Avatar
    Nov 2011
    chicago burbs
    outside temp sensor
    Can someone tell me where the outside temp sensor is located? ('12 wrx) I don't think my outside temp is accurate so I'm curious if maybe its dirty or something. Also what does it mean when the temp display on the dash blinks 3 times and then "updates".
    Nov 2011
    chicago burbs
    ump
    Negative pantsy rage-wrx's Avatar
    Aug 2010
    Yonkers/NYC
    I believe it is on the top of the dash. A little round plastic piece right in front of the clock/temp display near the windshield. At least that is what the manual tells me where it is on the Forester.
    -Tony
    2011 WRX WRB Stage2
    2012 FXT DGM
    The Big 2011/2012 Mod Thread
    "Just Leave me alone. I know what I'm doing"-
    Kimi Räikkönen
    Nov 2011
    chicago burbs
    outside temp sensor
    I looked through my manual also but couldn't find the answer. So if that's the sensor it must calculate (or make an educated guess) the temp outside?
    Registered User jrb5783's Avatar
    Jul 2011
    Altoona,Pa
    i think blinks when its below 37 degrees i think? to warn you that road conditions may be icy
    Nov 2011
    chicago burbs
    outside temp sensor
    Good thinking, that didn't occur to me. I'm pretty sure it was 37 degrees too.
    Aug 2010
    Yonkers/NYC
    Yes,it does blink when it goes below 37 degrees. That happened today just some time ago. I had not noticed this before.
    -Tony
    2011 WRX WRB Stage2
    2012 FXT DGM
    Kimi Räikkönen
    Apr 2007
    8000' up in Colorado
    Just to clarify, it blinks only at 37 degrees and not any time it's below that temp. The purpose is to warn you that even though the air temp is above freezing, it's entirely possible the ground temp is below freezing so roads may be icy. So if you start the car and it's exactly 37 it'll blink, or if you're driving and it goes from 38 to 37. I'm trying to remember if it blinks when it goes from 36 to 37, but I can't remember...
    I thought the temp sensor was located in one of the holes in the front bumper? Maybe it's different on the '11 and/or the STI? Or maybe I'm thinking of my Porsche and/or my '04 STi? I recall a small black item about the size of a AAA battery with a single wire running to it that was clipped to the edge of one of the air intake holes...
    Scott
    Aug 2010
    Yonkers/NYC
    I am basing the location of the outside temp sensor off of reading the manual for my 2012 Forester XT for the first time the other day. I assume it is the same for the WRX. But I have to check. Yes, it did blink today when it went for 38 to 37. Don't know if the same happens when it goes from 36 to 37.
    I was also driving my sister's VW CC & there was an audio warning over the audio system telling me that temp had dipped below 40 degrees.
    -Tony
    2011 WRX WRB Stage2
    2012 FXT DGM
    Kimi Räikkönen
    Texas, United States
    Quote Originally Posted by rage-wrx View Post
    Are you sure it was referring to the outside temp sensor and not the cabin temp sensor for the climate control system?
    Aug 2010
    Yonkers/NYC
    No, the inside temp sensor is located on the dash near the right side of the steering wheel at the 4 o'clock mark.
    -Tony
    2011 WRX WRB Stage2
    2012 FXT DGM
    Kimi Räikkönen
