Results 1 to 4 of 4
This is a discussion on possibly having a tune issue within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I have a 2002 WRX and it USED to have a stage 2 tune on it. The guy I bought ...
    May 2011
    I have a 2002 WRX and it USED to have a stage 2 tune on it. The guy I bought it from said he re-flashed the map back to stock. It also had TGV deletes. It still has the deletes, but is stock. It has a wondering idle when I start it, and when it warms up it levels out. But when I'm driving it it sometimes doesnt want to boost right, like hesitates and when I stop and its in neutral it almost bogs down enough to stall. I AM getting a P0171 I think it was..if it wasnt that, then it was close to it. Its not with me or I would scan it again. Basically it was running lean is what it scanned. The guy I bought it from said he thought the problem was a vacuum leak. I have never dealt with tunes before, so its all new to me. But if anyone knows what I could do, that would help me out. I checked the plugs that you connect when you tune and he has them disconnected like it says too, so I dont know. I am going to check the fuel pump, and filter next unless someone thinks they know something otherwise. The guy I got it from also said he did the tune/de-tune open source, so ecu flash, romraider, and a tactrix cable. Do I need these things to fiure out what is wrong with it? Can anybody help?
    Lando Calrissian DemonWRX's Avatar
    Jul 2011
    Cloud City, Bespin
    'USED to have a stage 2 tune' and 'It still has the deletes, but is stock'
    wow.....
    If you are on a stock tune, you need tuned. TGV deletes are beyond a normal 'stage 2' level....what else is still in there? Does it have an intake? a downpipe?
    First, you need to go over the car and see what is currently installed. Then you need to flash to a tune that supports those parts.
    edit: Additionally, TGV deletes are normally not done till you are at least planning on a larger turbo and injectors.....do you know if those were changed and still in the car?
    Stink-Eye Mob #39
    N.E.R.D. Operative #8
    May 2011
    Yeah, it's a bit to swallow for me. Ok, it has an up-pipe, stock down pipe, 3 in catback, turbo silicone inlet/air intake hose. Stock air box and he told me it had the stock injectors for both stock and stage 2. I thought the same thing for a stage 2. But it has stock injectors and turbo. Nothing else on it. Why would it be running lean?
    Jul 2011
    Cloud City, Bespin
    Well, start off by reading this....
    Unabomber's Manifesto - TGV Deletes FAQ - MySubie.com
    edit: it would help to know specifically what code you are getting.
    Stink-Eye Mob #39
