Results 1 to 15 of 17
This is a discussion on Is the clutch on warranty? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; My clutch is slipping and my car is syill on warranty, should my clutch be covered on warranty?...
    Sep 2012
    Oct 2011
    Santa Ana, CA
    Shutting up.
    Texas, United States
    It's covered by the warranty. I've had two replaced by Subaru under warranty. Although they can easily say it went bad due to abuse and deny your claim if they want to.
    Sep 2012
    Thanksbfor sharing your history. I guess I will talk with the dealer and pray its covered. Also, do you think if i got a stage 3 clutch they would install it for me instead of the oem one?
    Cheeky Bastage! spirited09wrx's Avatar
    Oct 2009
    Dirty Jerz
    I had a clutch replaced under warranty as well
    Zach
    Teh Intern @ WTF Tuning, LLC
    2009 WRB Subaru Wrx Sedan: WTF Tuning Stg2
    Stink eye Mob #287
    N.E.R.D. #43252003274489856000 (the total number of configurations of the Rubik cube)
    "It's not turbo-lag, it's foreplay"
    Aug 2012
    Bristol, CT
    Quote Originally Posted by natbea09 View Post
    uhm, no. More then likely they'll look at you funny. Covering a warrenty claim to put in an aftermarket just screams abuse
    Sep 2012
    True. Well, I will be happy enough if I can get it replaced then. Thanks for ur input all.
    Sammich Makin' Princess Leia wrxtreme06's Avatar
    May 2007
    orlando flawduh
    What mods do you have that warrant a stage 3 clutch?
    desiree
    06 impreza wrx tr
    : cobb stage II - protuned by STi_Mikey!
    hawk-eye alliance #11:11 //
    wingl3ss @ll!ance #17 // lvl 80 N.E.R.D.
    facebook
    Sep 2012
    As of right now none. However, in the spring I will be looking at a fmic, injectors, fuel pump, intake, turboback exhaust, external wastegate+uppipe, and possibily a turbo upgrade all with a protune.
    Aug 2012
    Bristol, CT
    What do you drive...WRX?
    Plan on rebuildig the tranny a few times too
    Sep 2012
    Yes a wrx and I shouldnt have to worry about the trany unless I go well o ver 400whp.. my goal is to get mid to high 300's
    They will install it no problem, the question is whether they would be willing to use your warranty to cover the cost of labor. This isn't unheard of, so it might be worth asking (although like nsibanez said, it might start them thinking about abuse).
    As far as the transmission, people have been known to break the five speed WRX transmission at stock power levels. I'm assuming yours is a newer year model since you said you are under warranty, so it's probably a little stronger than the older ones. Even so, I would be weary of the transmission with anything over 330wtq. If you baby it you can get away with running more power than it is traditionally rated to handle, but it's still a gamble. I'm not sure what makes you think you wouldn't have to worry until over 400whp, you're probably thinking of the six speed that comes in the STi.
    Aug 2012
    Bristol, CT
    My tranny was rebuilt twice before I bought it.....
    It's never been modded... just beat on
    I have an aftermarket clutch too...apparently one of the last owners thoguht it would let him abuse it more... I can feel the scars every time I shift. You can just tell when it's been abused. I don;t even beat on my car at all. I baby the hell out of it and I still have problems. I seriously do not recommend adding too much power unless you;re going to do a tranny swap as well
    Sep 2012
    At this point im considering trading in for an STI. How much whp can their trannys handle?
    With responsible driving, 500whp give or take.
