Results 1 to 15 of 28
This is a discussion on Duty cycle within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I have a '12 wrx, where should the injector duty cycle be? On average modded or unmodded?...
    Registered User SubiEj255's Avatar
    Jul 2012
    Baltimore
    Duty cycle
    A car is only as good as its driver
    Jul 2012
    Baltimore
    Yea I figured that. I pulled logs my IDCs are 98%. This is with the Cobb stage 1 91 tune, while using 93 octane.
    Oct 2005
    Late Devonian
    How much boost are you hitting?
    Dec 2011
    Pottstown PA
    98% on a stage 1 tune! wow didnt think it'd be that much. And why arent u using the 93 octane tune if your using 93..?
    Jul 2012
    Baltimore
    This is by 7k redline. Peak boost is 16.8 or something like that. I don't have the exact numbers in front of me right now. It wasn't higher than 16.8, I do know that. I'm using 91 tune b/c I wanted to use that extra octane as an buffer to "richen" the car up. I k ow these cars run lean, so I wanted to have a small window.
    Jan 2012
    Philly Area
    Quote Originally Posted by SubiEj255 View Post
    Someone with more experience in tuning can correct me if I'm wrong, but I'm fairly sure that octane rating is not going to affect your A/F ratio, or as you put it "richen the car up."
    - William
    Oct 2005
    Late Devonian
    Correct, the octane of the gas won't directly but the map will probably give a buffer against knock. I'm not sure how Cobb does it, but the 91 octane map probably uses less timing or a richer mixture to keep the 91 octane gas from knocking. I'd run the 93 map and see for yourself if there is a knock issue or not.
    Jan 2012
    Philly Area
    Yeah, I just re-read that post and realized I may have interpreted what the OP wrote incorrectly. The 91 tune might possibly be richer for safety. However, I believe that using 93 gas on a 91 tune is not going to help with anything unless for some reason 91 gas was knocking on the 91 tune, correct?
    - William
    Jul 2012
    Baltimore
    I pulled logs for both tunes. Knock isn't the issue in either tune. Ill post both with I get to my computer, but the question was the duty cycle of the injectors; why are they almost maxed out? Is this normal? What are the size of the stock injectors?
    Oct 2005
    Late Devonian
    It doesn't seem normal to me - it is too high.
    Was the duty cycle lower with the 93 map? If it is a leaner map....
    Jan 2012
    Philly Area
    If there was no knock when running the 93 tune, and you use 93 gas, you should just run the 93 tune. If you are concerned that it might lean the car out too much, contact Cobb and ask them how the a/f ratios differ between the 91 and 93 tunes. Or save some money and just buy 91 gas for the 91 tune. Running 93 octane gives no additional benefit if you are on the 91 tune with no knock issues.
    To your questions: All you have is a stage 1 tune, no other mods? If so, that seems not normal. Stock injector size is 565 I believe.
    - William
    Oct 2005
    Late Devonian
    16.8 psi seems high for a stage I tune, but I think that may be normal for the new maps.
    The injectors should be <90 on a stage II map, so there is something funny going on for sure.
    zax
    zax is offline
    Taco Boy zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Unfortunately, the new ATR won't allow me to view the 2012 maps, but classically, Cobb has traded very rich fueling for added timing.
    Facebook me here
    Moderator Donkey's Avatar
    Da boonies
    This. Use the 93 map. The 91 is richer. Plus OTS maps will run rich. I would see about getting a custom tune. Also colder weather = higher duty cycles.
    2002 FORESTER S
    1998 FORESTER S
