Results 1 to 15 of 15
This is a discussion on Oil leak, trying to pin point within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; 2003 WRX Sedan So when at a red light i noticed that nice smell of burning oil.. When i popped ...
    Registered User dburke911's Avatar
    Sep 2012
    SC
    2003 WRX Sedan
    So when at a red light i noticed that nice smell of burning oil.. When i popped the hood there was smoke coming from the back left side of the engine, near the turbo. a decent amount of smoke. Oil level was pretty damn low. I bought some oil, dumped about 1 qt into the motor however without any daylight left ill wait untill tomorrow to turn the engine on and/or look for possible leak location. any good spots to check for leaks? common problems?
    Aug 2012
    Bristol, CT
    just pp the hood and start looking at the highest point. Any guess would be the valve covers
    Aug 2012
    Bristol, CT
    I mean, sounds obvious when looking for leaks, but that's all you can really do. I've heard mostly the valve cover gaskets from the bugeyes. Start there. Hopefully it's just that because they're simple maybe?
    But if you say smoke is coming from the engine bay, its coming from just that.
    Registered User DiRty Impreza's Avatar
    Jun 2011
    Canton, Ohio
    its probably your oil feed line.
    ++ + ++P3LLA++ + ++
    06 STi ( Stage II ) BOOSTED
    HAWK-EYE ALLIANCE # 808
    Sep 2012
    SC
    if its the turbo feed or drain line, is it a faulty gasket or is it loose or cracked?
    Oct 2011
    Santa Ana, CA
    Re: Oil leak, trying to pin point
    Check the cv boot too. A fresh cv boot spill looks and smell like a nasty oil leak, with a hint of burning rubber.
    Posted from a fone.
    Registered User InsaneManiac's Avatar
    Jun 2012
    San Diego
    Drain the oil. Put new oil in and then stick some cardboard under the thing. See where exactly the oil is leaking from. When it comes to the smoke it could be your cv boot flecking grease up on the down/up pipe and the grease is basically burning off and making it look like it's smoking. A suggestion, jack your car up, inspect from the top and the bottom, inspect closely for any large amounts of grease/oil. You might find the leak. Possible your oil feed line could be leaking or the gaskets aren't working. Without close inspection you will not be able to really tell.
    Dec 2011
    Pennsylvania
    had a very similar issue with my 02 WRX. Valve Cover Gaskets were the issue.
    Aug 2012
    Bristol, CT
    Quote Originally Posted by InsaneManiac View Post
    You could test it with dye too, and it should stand out a little bit more.
    Oct 2005
    Late Devonian
    Quote Originally Posted by UEDan View Post
    Posted from a fone.
    Best guess by far right there.
    This is the only place I would get an axle unless you want to pay full price for a new one from the dealer.
    http://www.ccrengines.com/mwe/
    Moderator Donkey's Avatar
    Da boonies
    NAPA has axles for around $60 if you have one local.
    2002 FORESTER S
    1998 FORESTER S
    Sep 2012
    SC
    Thanks everyone, much appreciated
    Sep 2012
    harleysville, pa
    I am having this same issue right now on my bugeye, I took it to the dealer and they said it was the valve cover gaskets were bad and quoted me $600 to repair it.. I ended up buying new gaskets and did it myself and cleaned all the old oil off and it's still leaking so I glad I saved myself the $600 but I'm still pissed that its leaking, I thought it could be the feed/return lines as well but I'm not sure, I guess back to the dealer I go
    Da boonies
    Finding leaks is not that hard. It a pretty common sense method. Go to your local DIY car wash and clean the soiled area with a pressure washer and engine degreaser. Drive car. Jack up car and look for leak. Buy a mechanics mirror to help look in tight places.
    2002 FORESTER S
    1998 FORESTER S
    Sep 2012
    harleysville, pa
    I went to the car wash after replacing the gaskets and cleaned off all the old oil and grease that had built up over the years and by time I got home about 5min drive there was already fresh oil on the uppipe and lower control arm and axle but the rear of the valve covers looked dry and after a couple days (thurs-sat) its smoking just as bad if not worse since I replaced the gaskets and its only on the passenger side. I'm dropping it back off at the dealer tomorrow morning hopefully I can get this taking care of asap
