Oil leak at head? Help
Results 1 to 15 of 20
This is a discussion on Oil leak at head? Help within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I recently had my oil changed by my mechanic. He told me that my 2011 wrx was leaking oil from ...
    Registered User jmb8806's Avatar
    Apr 2007
    Exton, Pennsylvania, United States
    I recently had my oil changed by my mechanic. He told me that my 2011 wrx was leaking oil from the head and to take it to the dealer. I dropped it off this morning and they told me that the leak was coming from the penzoil oil filter and that the oil plug. The guy said that the washer for the oil plug has to be replaced every oil change. Anyone ever hear this or am I just getting the run around
    Registered User DiRty Impreza's Avatar
    Jun 2011
    Canton, Ohio
    Its called a crush washer, and you should replace it every oil change correct.
    ++ + ++P3LLA++ + ++
    06 STi ( Stage II ) BOOSTED
    HAWK-EYE ALLIANCE # 808
    Aug 2012
    Tucson, AZ
    You might be able to get away with 2 or three depending on how tight you torque the drain plug. But it's always safer to replace it every oil change. Same with the filter, obviously always needs to be replaced, but, if you over tighten non oem ones such as penzoil they're pron to leaking
  5. #4
    Moderator Donkey's Avatar
    Da boonies,Va
    Fumoto oil drain valve FTW.............
    Fumoto Valve | Qwik Valve™
    2002 FORESTER S
    1998 FORESTER S
  6. #5
    Apr 2007
    seems like an awesome add on, anyone use one on an 2011?
  7. #6
    KHP
    KHP is offline
    Registered User KHP's Avatar
    Oct 2010
    Reno, NV
    Quote Originally Posted by jmb8806 View Post
    I have one on my 2011 WRX. I got the version that doesn't have the spout. It makes for 10-15 minute oil changes and UOA sampling a breeze. I've had it on for about 20,000 miles now without any issues.
    2011 WRX Limited Spark Silver (5 Door)
  8. #7
    Oct 2005
    Late Devonian
    It is possible indeed, however it is a little hard to say who is to be trusted. You either need a new mechanic or a new dealer.
  9. #8
    Apr 2007
    ok so heres where i stand...dealer told me that the oil was from the non oe filter, and the fact that the crush washer was not replaced. this afternoon i bought a oe filter and a new crush washer and went back to the shop i had it changed and had it changed again using the oe filter and new washer, additionally they cleaned all the oil from underneath my car. Im taking it back in a few days to have them check it out and see what it looks like. I trust my mechanic because its my older brother, several other of his co workers looked at today as did i and the fact that the dealer told me that the oil blew up onto the head from the filter or plug seems very unlikely. unless oil now defies gravity. but i guess ill see when i check it out in a few days. it also dawned on me that i purchased an extended warranty so if there is a problem that the dealer wont fix that should cover it i think.
  10. #9
    Oct 2005
    Late Devonian
    Sounds good. I'd stick with the OEM oil filters either way - there are solid arguments for that.
  11. #10
    Aug 2012
    Tucson, AZ
    ya, if you have oil above your filter and plug, its something else. If it's just above it though it's still possible, I'm talking about 7+ inches above the spot the dealer says it's coming from. It's very likely it's just those spots though. Especially if you've had the oil changed before and they didn't clean it very good. People come back all the time saying they have an oil leak and it's just residual
    As far as taking it back for someone else to look at and see if it's leaking, you can do it yourself for free in your own driveway. Just remove the splash shield, not too hard, lookat the drain plug. If it's still leaking from there with a new washer, check to see if it's tight. If it is tight suspect a stripped oil pan. Gotta love aluminum. As far as the filter goes, make sure it's torqued to the OE specs...if it's still leaking with an OEM, don;t really know what to tell you. Never seen them leak for any other reason other then not tight enough,or over tightened.
  12. #11
    Apr 2007
    I could do it in my drive way but using a lift is just easier haha. And this was my first oil change I've done on the car since I bought it about 2 months ago so I don't know if it was clean before or what. But it was spotless after my brother cleaned it today so well see how it looks in a few days if the oil is back where it was (up on the head) it's unlikely that its coming from the plug or filter assuming they won't be leaking but it's really a waiting game now
  13. #12
    Aug 2012
    Tucson, AZ
    Upon the head....by the fill hole?
  14. #13
    Aug 2012
    Tucson, AZ
    Ya, it is always easier to use a lift. Lucky work lets me use mine every Wednesday...but I noticed I was leaking from my drain plug gasket. Just stick your head under there, and you'll see it =p
  15. #14
    Oct 2005
    Late Devonian
    lol I've done that. Could be good thinking.
  16. #15
    Apr 2007
    That was all covered
