only 10lbs of boost!help=( - Page 2
Page 2 of 5 FirstFirst 12345 LastLast
Results 16 to 30 of 66
This is a discussion on only 10lbs of boost!help=( within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Update on the underboosting. I went to Subaru got the restrictor pill , replaced it, and still under boosting ;(x ...
    Oct 2012
    Update on the underboosting. I went to Subaru got the restrictor pill , replaced it, and still under boosting ;(x anyone think it can be the boost control solenoid?
    Oct 2005
    Late Devonian
    Quote Originally Posted by scobby07 View Post
    You really need to do the log next. It isn't hard. If there is a large boost error in the log, it is likely the BCS or a boost leak.
    It may just be that your gauge is off or you are running the wrong map. You should post what map you are running, which you can easily find out when you plug in the AP.
    Again, the AP is a powerful tool - you need to learn how to use it for these basic things.
    Oct 2012
    Removing line 4 tells you nothing, the BCS just vents to atmosphere then which will skew your MAF reading but will not affect boost.
    Don't remove line 3 without plugging the T off at the turbo end (or else you will have run-away boost) - that will tell you your wastegate spring pressure. That is worth checking as if your spring is weak you will boost less. I'd test it by running a new line directly from the compressor to the wastegate actuator though.
    It is likely your BCS or possibly the restrictor pill, vacuum line size, or T-fitting size.
    i think you might be right about those things. Yesterday, I replaced the restrictor pill and the hose with it and still nothing.
    can it really be the vacuum line size or t fitting size??? How can i Test the bcs?
  6. #19
    Oct 2012
    how do i get to the log??
    I dont think the gauge is off because it does not run as strong as I think it should considering i had a stock evo and think the evo is way faster.. Can running the wrong map really make me boost less??
  7. #20
            MainFrame's Avatar
    Austin, TX
    Since boost is pretty much entirely controlled by the map, absolutely.
  8. #21
    Oct 2005
    Late Devonian
    You can only really test it by swapping in a known good one. You can hook it up to 12 volts and listen if it clicks, or put the car in test mode to listen and it might work as well. If it doesn't click it is likely dead.
    Are you adverse to using your AP for some reason? It isn't any harder than using a cell phone.
    How are you measuring boost? If you are just using a gauge it is highly suspect, especially if you didn't see it change from a higher level.
  9. #22
    Oct 2005
    Late Devonian
    Sorry our posts overlapped -
    Yes it can be the map. There is a youtube video that shows how to log.
    Here
  10. #23
    Oct 2012
    Okay I will log today afternoon,
    And also is it a good idea to try to disconnect the hose from the wastegate and tell if it will boost higher than 10lbs? I will use the Cobb ap to measure the boost and my boost gauge at the same time to not overboost
  11. #24
    Oct 2005
    Late Devonian
    No don't do that. I'm sure it will boost higher unless you have a major leak. If you do have a major leak, you will just be way overworking the turbo. You can't watch the AP all that well, and if you boost to far this will all be for not.
    Also, what the AP tells you your boost is you can trust. If your gauge doesn't match up, it is the gauge.
  12. #25
    Registered User benson156's Avatar
    Sep 2008
    Utah
    Thanks for clearing that up. I guess I could have looked it up myself. You've further helped my laziness
    No problem! Did this ever get sorted out? I've been on night shift this week so I haven't been on at all. I know that there's something screwy, I test drove an 03 Evo with a few mods before i drove mine and it didn't have as much pull as my stock STi. That's what settled it for me. Scobby07, did you ever check on the AP to see what current map your running or send a datalog to anybody?
    Hawk-eye Alliance #156
  13. #26
    Oct 2012
    but isnt that the point to check if it will boost higher? I read that if it boost higher then it is the boost control solenoid and thats a problem fix =)
  14. #27
    Oct 2012
    Time
    0
    0.16
    0.29
    0.44
    0.6
    0.74
    RPM (RPM)
    2098
    2103
    2120
    2126
    2116
    2119
    Ignition Adv. ()
    46
    46
    46
    46.5
    47
    47
    Learned Ign. ()
    0
    0
    0
    0
    0
    0
    Boost (PSI)
    -4.79
    -4.79
    -4.79
    -4.93
    -5.51
    -6.53
    Wastegate Duty (%)
    1.18
    1.18
    1.18
    0.78
    0
    0
    MAF Voltage (V)
    2.08
    2.08
    2.06
    2.04
    1.94
    1.84
    Fuel Trim (Long) (%)
    2.34
    2.34
    2.34
    2.34
    2.34
    2.34
    not sure if this helps i got it from the data log
  15. #28
    Oct 2012
    here is the data log i got.
    anything wrong and why im not boosting stock??
  16. #29
    Oct 2012
    the first data i manually wrote is wrong that was the previous owners and idk what that was for
  17. #30
            MainFrame's Avatar
    Austin, TX
    I'm not that familiar with AP logs, but from the looks of that there is something seriously wrong with your car, not the boost problem. Actually, it's a good thing it isn't reaching full boost because you might have already blown the engine if it was making full boost.
    I would say the proper way to post a log would be via google docs, but if that was my car I wouldn't drive it again until I figured out what was wrong.
    Disregarding the low boost, you are seeing some significant knock, and your DAM has dropped all the way to 1. Timing is pulled WAY back, and you're still knocking.. something is wrong.
