Page 1 of 5 12345 LastLast
Results 1 to 15 of 62
This is a discussion on The Type of octane to use? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; i was reading through ome threads and guy said he need 85 oct to run his wr sti.. i run ...
    Oct 2012
    Newark/Hillside,New Jersey
    i was reading through ome threads and guy said he need 85 oct to run his wr sti.. i run 93-95 what's the difference i thought the high the better unless i misunderstood. help if you can..thanks
    You need 91+ fuel
    Texas, United States
    91 minimum, 93 is better.
    Oct 2012
    would there be purpose to running a lower octane? isnt the higher octance better for your car in most areas?
    Jun 2012
    Boca Raton, FL
    higher or lower octane is not better or worse, it's different. High octane fuel is hard to ignite. The key is to use the proper to slightly higher octane required for your engine.
    Oct 2012
    i thought the higher octane is the greater power when ignated therefore better perfomance in the higher torque/hp area
    Quote Originally Posted by Mf645 View Post
    Oct 2012
    ignited**
    The higher the better in turbo charged cars. The lower ignition point of lower octane fuel makes it much more prone to knock, which is probably the number one killer of these engines.
    Oct 2012
    we wouldnt want that now would we
    Quote Originally Posted by Kevin Pedrosa View Post
    Nope.. but with the higher ignition point the car can be tuned more aggressively before it starts knocking. Increases in timing and boost made possible by running higher octane are what produce more power.
    It's also possible to run a leaner mixture with more knock resistant fuel, which also produces more power.
    Oct 2012
    leaner mixture? such as racing fuel?
    No, leaner AFR.. less fuel, more air. The leaner the mix the hotter the combustion temps get and the more power it makes.. until it knocks, or melts something.
    Oct 2012
    what you mean by knock... like engines actually start knocking?
    Kind of. Knock is when the fuel mixture in the cylinder isn't igniting at the correct time. The factory knock sensor is basically a microphone installed in the block that listens for a particular frequency of sound associated with combustion. If the gasses in the chamber aren't combusting at the right time it can cause all kinds of damage.
    Engine knocking - Wikipedia, the free encyclopedia
    Registered User jeremydingeman's Avatar
    Mar 2012
    Bothell, WA
    Ill bet the guy was referring to using E85.
