Results 1 to 7 of 7
This is a discussion on Possibly Thermostat Problem?? Help needed!! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hey how we all doing? First time on here so hope i posted in the right place? I have a ...
    Oct 2012
    Hey how we all doing? First time on here so hope i posted in the right place? I have a wrx sti wagon 1998 have looked after this car for a few years now and has done me really well. Just yesterday i noticed that my temp wasn't going up much over the line at all after i had been driving around at least an hour. I have been told that it could be a thermostat problem? If so is there much work involved as i need my car for my job? And also where you put your coolant after a few days that green goes brown not sure why this is can anyone tell me please??
    Suspect thermostat stuck open and need coolant flush. Coolant flush done with thermostat routinely. Use authentic parts. One hour job. Burp the system extensively.
    Oct 2012
    Ok thank you so much for the advice will do that now and in future!! .. Cheers Also is it ok to drive around??
    Texas, United States
    It's not really good for it if it isn't getting up to temperature. You can drive it a little bit, but I would try to get it fixed as soon as possible.
    Aug 2012
    Bristol, CT
    Is it blowing any hot air at all after driving?
    Oct 2012
    Yeah will get it done tomorrow hopefully!? Umm can't see it blowing any hot air is that bad?
    Aug 2012
    Bristol, CT
    Bad thermos or maybe a stuck gauge
