Results 1 to 15 of 18
This is a discussion on first tune not so good within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; So i had a couple problems, some bad some not so bad. 1st- My intercooler was leaking (solved for now) ...
    Aug 2012
    north jersey
    2nd- My mbc wasn't working right. boost was up and down
    3rd- 2 spark plugs were cracked!
    4th- Tune was not completed because i need to figure out another issue. He said my timing was jumping across the map. He said maybe its bad gas or I need to do a compression test. Which i am doing tomorrow.
    Anyone know of anything else I should check for?
    08 wrx 66,000 miles
    Perrin intake
    Borla muffler
    DP no cat
    MBC
    Spark plugs don't just crack. Find out why. Look carefully at fueling vs. timing because I can't imagine how this happened otherwise.
    Aug 2012
    north jersey
    he said they were probably put in wrong..
    Aug 2012
    north jersey
    compression test
    #1 & 4 are 135.
    #2 & 3 are 140.
    What is the specs? Im looking and i think those are good but find sti's not wrx. I dont know if there is a difference
    Mt. Laurel, NJ
    Those aren't really that bad though a little low, and they are all pretty consistent with each other which is what you want. Anywhere around 140 and above is considered normal.
    Aug 2012
    north jersey
    leak down test is next the tuner said. if i pass bad gas or coil
    Aug 2012
    north jersey
    those readings are cold motor btw
    Mt. Laurel, NJ
    Isn't the compression test supposed to be done on a warm motor?
    Aug 2012
    north jersey
    ive read both but according to him there fine. im getting the leak down anyway
    zax
    zax is offline
    Moderating the World! zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    That's OK for a cold motor. You should be doing compression tests on a warm motor per the shop manual (coolant temp > 100 degrees C IIRC)
    Facebook me here
    Aug 2012
    north jersey
    whats the best way to do leak down
    Aug 2012
    north jersey
    turn the crank to build pressure than read gauge?
    Moderator Donkey's Avatar
    Da boonies
    You can do a compression test on a cold motor but you generally want to add some oil to the cylinders first. You don't want to do it dry. You can just pull the fuel pump relay and crank the motor over a couple times. But you do get more accurate results on a warm motor.
    Also for future reference: Technical Articles
    2002 FORESTER S
    1998 FORESTER S
    Da boonies
    Quote Originally Posted by Fusionf21 View Post
    Uh.....no. You need an air compressor and the cylinder needs to be TDC on the compression stroke. Google " cylinder leak down test"
    http://www.carcraft.com/techarticles...r/viewall.html
    2002 FORESTER S
    1998 FORESTER S
    Aug 2012
    Bristol, CT
    Over torqued when they got put in could it it right?
