Results 1 to 11 of 11
This is a discussion on 2013 WRX Turbo Oil Outlet Tube leak within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; My shiny new 2013 WRX Base 5-Door went in for its first oil change at about 1,100 miles, and to ...
    Sep 2012
    My shiny new 2013 WRX Base 5-Door went in for its first oil change at about 1,100 miles, and to my surprise the dealer found an oil leak coming from the Turbo Oil Outlet Tube (part #4 on the attached illustration). It's a slow leak, but still needs to be addressed. What surprised me is that this part was not in stock, leading me to believe that this sort of leak is pretty rare. The part is coming in and will be installed this week.
    Just out of curiosity, has anyone else encountered this problem?
    Chris
    Registered User Dgmftw's Avatar
    Sep 2012
    Ormond Beach
    I would assume that would be rare I have no leaks on my 13, I did however have to harass the living sh*t out of my service manager to change my oil at 1k they swear by their 3k for first oil
    Sep 2012
    Quote Originally Posted by Dgmftw View Post
    Yeah, I did get a funny look from them about the mileage, but it was my $75, not theirs. From now on I'll go in at 3,500 mile intervals, most likely. They had to remove the turbocharger to install this part, it must have been ugly. Works fine now, though!
    Chris
    Aug 2012
    Bristol, CT
    They'll have a TSB for it soon I'm sure
    Nov 2012
    Ive got a 2013 wrx base 4door and I am noticing a leak in the same area. Might be a similar problem.
    Dec 2012
    A, A
    i have the same problem too, have the service fixed like two times, it still leaks.... im going to let them fix one more time before i call lemon law, my car only have 3000 miles on it.
    Texas, United States
    I would assume it's uncommon on a new car.. but that is one of (if not the) most common area for oil leaks on older modified cars.
    Replace the tube, be extra careful with the install, clean the area well, then inspect it in a week.. problem should be solved. (dealership should do it under warranty no problem)
    Moderator Donkey's Avatar
    Da boonies
    It doubt it's coming from the actual tube itself and maybe a gasket or the drain tube. It's a gravity drain. The gasket is $5. Even if it was the tube I would just JB weld it and not buy new.
    2002 FORESTER S
    1998 FORESTER S
    Dec 2012
    A, A
    Dec 2012
    A, A
    Have an appointment with the service on Monday, I totally bitch at them!! I told them this is going to be the third time and also the last time, before I call lemon law!
    Dec 2012
    A, A
