Results 1 to 5 of 5
This is a discussion on Headlight issue within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I just recently installed hids and they were working fine then one day the driver side stopped working, so I ...
    Jul 2012
    Indiana
    Headlight issue
    I just recently installed hids and they were working fine then one day the driver side stopped working, so I took them out and out the stock bulbs back in. The lights work except the driver side is super dim and the for some reason it seems the brights are on also( very faint but still on) have a picture what justice it does I'm not sure. Any help would be appreciated Click image for larger version.
    Could you have frayed or shorted wiring?
    Jul 2012
    Indiana
    Headlight issue
    That's what I've been hearing is maybe a short or a bad ground possibly
    Registered User Ingo's Avatar
    Mar 2012
    Colorado Springs, CO
    Definitely check into the wiring. My guess would be that something was wrong and the light that stopped working didn't get proper power anymore. The switch back to regular bulbs with the resulting effects suggests a wiring issue, obviously that wasn't there before...
    Jul 2012
    Indiana
    Headlight issue
    Alright will do appreciate the help
