Results 1 to 2 of 2
This is a discussion on Need help with clock display within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hi guys, i just bought a used 2002 wrx, and the clock is not on or not displaying anything. Any ...
    Registered User domokun's Avatar
    Oct 2012
    Hi guys, i just bought a used 2002 wrx, and the clock is not on or not displaying anything. Any reasons as to why this may be? Any help would be wonderful, thank you.
    2.0L snail power... Rambo's Avatar
    Oct 2010
    Korea/Japan/Taiwan/USA
    Well, they do burn out with age, so either it's unplugged for some reason (doubtful), or it's burned out. Search around for how to pop out the clock pod. Basically use a plastic screwdriver and wedge it out (there are no screws holding it in, just clips), and check the connection. If you have a multimeter, also check for 12V from the power line.
    If those are all good, then it's just burned out. Either find a used one in the classified, or replace it with a 3-gauge cluster if you've been looking to add some gauges.
    Isaac -- 2003 WRX sedan Stg II
    He who shall be last, shall be sideways and smiling... - Jeremy Clarkson
