Results 1 to 3 of 3
This is a discussion on Air conditioning problem! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I own a 04' WRX and my A/C just doesn't blow cold... Anyone else have this problem or does anyone ...
    Oct 2012
    Vancouver BC, Area.
    I own a 04' WRX and my A/C just doesn't blow cold... Anyone else have this problem or does anyone know the solution to this?
    Thanks
    Rippel
    Jul 2010
    Cincinnati
    Not to be an a-hole but lots of people have a/c issues. The solution is to figure out what isn't working and fix it. There are so many things that could cause the a/c to blow warm,it would be silly to guess. If you don't own or have access to gauges and evac equipment, I would take it to a garage and have them diagnose it.
    Stink eye mob #727
    2011 WRX DGM Hatch, Protuned Stage 1
    Registered User jeremydingeman's Avatar
    Mar 2012
    Bothell, WA
    The high pressure AC line is quite common to go bad. More than likely you have a leak somewhere in the system and you are losing refrigerant. Also not to be an a-hole but with a question that vague you are probably better off listening to jd92677 and taking it to your local shop. Sorry.
