All sounds like normal DRL behavior to me. Addressing #3, if you switch the headlights on with the switch and pull up the e-brake they should not turn off. But if the switch is turned to off and they go off when you pull up the e-brake, your DRL's are working as they should.
The only thing that seems off is the fog lights, but those turn on when you push the button to the left of the steering wheel (assuming these are factory installed).
LinkBack URL
About LinkBacks
