Results 1 to 6 of 6
This is a discussion on What's this sound? (Video) within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hey guys, I have a 2012 WRX Limited. It has a Cobb Intake, DP, AP (Stage 2). The car is ...
    Aug 2012
    Hey guys, I have a 2012 WRX Limited. It has a Cobb Intake, DP, AP (Stage 2). The car is making great power however, when gradually accelerating and entering higher boost levels I hear this sound... It sounds like when you let air out of a balloon once its filled by its mouth. (weird flutter type noise) I've searched the forums and most common problem is the TB to IC hose. I've removed the OEM clips and used T-Bolts and still have the same sound. Any advice?
    http://youtu.be/aKVCtWw87j0 (hard to hear.. it's around 2-3 sec into video)
    Registered User Soobvirgin's Avatar
    May 2012
    San Diego
    Quote Originally Posted by blkonblk17 View Post
    2012 Subaru WRX Weird Sound - YouTube
    All I hear is your intake sucking air.
    Registered User Mitch89's Avatar
    Oct 2011
    Bristol Tn
    2012 Subaru WRX Weird Sound - YouTube (hard to hear.. it's around 2-3 sec into video)
    Mine does this as well with the stage two everything you have. I think it's normal. I've checked everything it could possibly be. But i would like to know if it is in fact the intake whistling.
    Mt. Laurel, NJ
    Welcome to the sound an intake makes when the turbo spools up.
    Jul 2010
    Cincinnati
    Are you talking about that "flutter" type sound at max boost?
    Stink eye mob #727
    2011 WRX DGM Hatch, Protuned Stage 1
    Registered User hisdigness's Avatar
    May 2010
    So Cal (Torrance)
    I just ordered an AVO hose to replace the stock. I am installing it tomorrow and will let you know if that works.
