Coolant leak advice!!! - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 20 of 20
This is a discussion on Coolant leak advice!!! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Originally Posted by DennisWRX 07 WRX - hey guys, For the past month I have been chasing a slow coolant ...
    Aug 2012
    finding difficult coolant leaks
    Quote Originally Posted by DennisWRX View Post
    07 WRX - hey guys, For the past month I have been chasing a slow coolant leak that I have yet to find. I'm filling the reservoir every other day or few days. The car runs at normal operating temp but can smell burning coolant and about two times after driving there is steam in the engine bay. The dealer pressure tested it and could not find a leak. Then my dads mechanic pressure tested it and could not find anything and was pretty stumped. So I need any help or advice you may have to find this bastard. Thanks.
    Dennis,
    I am the tech manager at Prestone coolants. Sounds like a tough one to find. I use a dye in the coolant, you add it, run the engine for a while then use a black light to see the leak. You can buy the kits on ebay with dye for engine oil, trans oil, ac and coolant with the 12v blacklight for around 30 bucks. they work very well for finding difficult coolant leaks. Good luck and let us know if we can provide further information.
    Aug 2012
    Dennis, Prestone guy again.
    I also found this service bulliten
    NUMBER: 08-52-08
    DATE: 08/18/08
    APPLICABILITY:
    1999MY and later Impreza & Forester
    2000MY and later Legacy & Outback
    2006MY and later Tribeca
    SUBJECT: Coolant Overflow
    Introduction
    If you encounter a vehicle which experiences coolant coming out of the coolant reservoir tank, it may be caused by the radiator cap pressure valve being stuck open by debris sucked up through the reservoir tank hose. As the cooling system cools down, it sucks coolant back into the radiator. If there is debris that settles to the bottom of the reservoir tank, the hose is low enough to also suck them back into radiator. This causes the radiator cap not to seal, allowing excessive amount of coolant to escape overflowing the reservoir tank. If this condition continues over time, there will not be enough coolant in the system to maintain proper engine temperature.
    In order to correct the condition you need to clean (and test) or replace the radiator cap, clean out the reservoir tank, and shorten the hose slightly, following the repair procedure.
    Production Line Change
    The shorter coolant reservoir tank hose was used in production as shown above.
    Repair Procedure/Information
    1. Radiator Cap Cleaning
    Many caps can be successfully cleaned. The important part is the thorough cleaning of the negative pressure valve. If this is not done completely, remaining debris may result in a repeat issue. If there is an excessive amount of debris or the sealing rubber on the cap appears to be pitted or damaged, replace the cap.
    Note: If replacing the cap, skip to Step 2.
    Using clean water and a brush, thoroughly clean the cap seal surface.
    Note: A used toothbrush which has been cleaned works great.
    Manually open the negative pressure valve. Using clean water and a brush, thoroughly clean the valve (inner and outer surface) and the valve seal surface.
    Check the radiator cap valve opening pressure using a radiator cap tester to insure the cap is within specification (refer to the applicable Subaru Service Manual).
    Note: If the cap is out of specification replace it.
    2. Coolant Reservoir Tank Cleaning
    Remove the reservoir tank (refer to the applicable Subaru Service Manual).
    Using clean water, thoroughly clean the inside of the reservoir tank.
    Reinstall reservoir tank. Fill with coolant to the Full mark.
    Note: Be sure to use genuine Subaru Super Coolant or Subaru Long Life Coolant, depending upon what type of coolant is currently in the system.
    3. Coolant Reservoir Tank Hose Modification
    Remove the hose from the reservoir tank. Cut 20 mm from the bottom of the hose at a 45°angle. Reinstall hose in reservoir tank.
    Start engine and permit to fully warm up.
    Turn off engine and allow to fully cool down.
    Recheck coolant level in reservoir and add coolant if needed.
    Warranty/Claim Information
    Registered User shadowpr's Avatar
    Jan 2011
    TX, NY
    Have you checked your oil?
  6. #19
    Nov 2015
    Hey, I'm having the same problem now, on a 2006 WRX. I was wanting to see if you had figured out what problem you had and how you fixed it. I have an upgraded 3" downpipe, upgraded lightweight crankpully, aftermarket Perin headgasket, and a stage 2 cobb accessport tune. I just recently bought the car and only had smoke/vapor in the engine bay and hoodscoop once, but that was enough to garage it until further notice. Any insight would be very welcome, thanks!
  7. #20
    Nov 2015
