ECU or other ignition problem
Results 1 to 3 of 3
This is a discussion on ECU or other ignition problem within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hi there, i have a problem with my car... i think it may be the ECU, but i'm not sure. ...
    Aug 2012
    Hi there,
    there is the symptoms: when car is between 1500 and 2800 rpm, it give some knock (just like it was on the verge of chocking).
    when the car is over 2800 rpm (let's say 3000...), everything runs great (no power lost). The car dont have any check engine light on (so no code).
    This problem has happen since we boost the car, and we accidently short-circuit when we done it (not the proper order, some sparks have appears and i blow a fuse).
    any idea of what going on??
    No. What does "boost the car" mean and what modifications are done? Any CEL codes stored (you checked for codes stored not just visible CEL now)? What model car?
    Is "boost" to jump start? Have you checked all fuses and relays? Are the mains wires to the battery tight?
    Aug 2012
    Im going to take a look for all this, especially the relays (which i haven't cheked so far, but all the fuses are ok). How am I supose to see if a relay is ''broken''?
    Boost a car is effectively jump start a car (i speek french sorry).
    the model is a 2002 wrx sedan.
