Results 16 to 30 of 42
This is a discussion on A bit worried. Black smoke within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Ok I am 99% sure the down pipe is after market. It looks like a full turbo back exhaust....
    Registered User TurboWill's Avatar
    Mar 2004
    LI NY
    2009 wrx Dark grey metallic
  2. #17
    The Fruit mangostick's Avatar
    Oct 2009
    VB VA .. the ghetto on the sea
    is the computer a little guy that looks like this ?
    If so, that's the access port I was referring to. If you have that lil guy you're in much better shape than not having one, and that also means that if you need or want to you can go back to a factory downpipe and simply re-flash a factory or stageI map back on.
    Before you do any of that though, check the downpipe for names/logo's and see if there's a decent sized bulge in it. let us know what you find.
    fyi, if its catless.. that will explain the odd smell like an old car would have when it fires up. First cold start cars run very rich for a few seconds (same affect as a choke on a older car or truck) then even out as they warm up.
    OBP 2010 5dr *traded*
    SWP 2013 FRS
    SUCH IS MANGO!
  3. #18
    Mar 2004
    LI NY
    Yup that's the computer. I will check the downpipe later again and look for the cat. I'm pretty sure there are two on the stock exhaust system. One in the down pipe and one in front of where the catback attaches?
  4. #19
    Registered User xFalleNx's Avatar
    Nov 2010
    Moorestown, NJ
    Could you post some pics of the dp/turbo area so we can maybe try to figure out what is has on it?
    --Anthony 2011 DGM WRX stg2+sf intake + custom front end deer mod!
    Official Subie owner as of 01/10/11
    Stink Eye Mob #87
    Bye bye Bimmer
    Hellooo '11 REX
  5. #20
    Mar 2004
    LI NY
    Yes sure, I will be home around 3pm. I will deff post pics later
  6. #21
    Resident meany-rator 06wrx4me's Avatar
    Jun 2006
    Nor Cal
    Hate to be the bearer of bad news, but the 09's had ring failures and coughed motors at about your mileage. Most were replaced under warranty.
    It very well could be burning oil you smell and an early indication of doom. I would suggest putting the car back to stock (beg borrow steal parts), and drive to your local subi dealer to have it checked out under the 5/60k warranty. I'm sure they are aware of the 09 issue.
    09 WRX Engine Failures
    2009 WRX engine failure VIN/build date owner list - NASIOC
    2009 WRX Engine Failure Poll - NASIOC
    2009 Impreza WRX motor issues - NASIOC
  7. #22
    Mar 2004
    LI NY
    Oh great.... I am trying to find a stock exhaust
  8. #23
    Oct 2009
    what? ... ring land issues were only on STI's and the bearing problems were only for 09 wrx's with a build date in august of 08.
    Neither failure would lead to what the OP is seeing/smelling (only just after startup).. and both would amount to quite a bit of knocking noise. Wouldn't hurt to check it out but I'd first check the build date.. if it doesn't fall in the 8/08 range then dont worry about it.
    FYI OP, the only cat you have to worry about is the one in the downpipe. I haven't looked at my factory dp in forever but I'm pretty sure there's also only one cat in there too. Some aftermarket dp's do have the cat mounted further downstream (right before the O2 sensor bung) but most have them up near the back of the turbo. Should be easily visible from the top side with the hood open.
    also, read up here about your tuning device
    http://www.cobbtuning.com/AccessPORT-s/70458.htm
    SWP 2013 FRS
    SUCH IS MANGO!
  9. #24
    2.0L snail power... Rambo's Avatar
    Oct 2010
    Korea/Japan/Taiwan/USA
    To be honest, I'd really just try and return the car if you can, before trying to do a bunch of your own work on it. You've got a good case to do so if it really doesn't have cats, and if it does, you might still be able to work something out. This could become an incredibly expensive headache quickly.
    Isaac -- 2003 WRX sedan Stg II
    He who shall be last, shall be sideways and smiling... - Jeremy Clarkson
  10. #25
    Mar 2004
    LI NY
    Uploaded with ImageShack.us
  11. #26
    Mar 2004
    LI NY
    Ok guys good news, I found out its full Cobb exhaust. I found out where it was tuned. if I prime the fuel pump twice then start it... NO SMOKE??
  12. #27
    Nov 2010
    Moorestown, NJ
    That looks like a Cobb Catted DP to me....see the 1st and 2nd pic that you posted?
    That lil "bump" looking thing is a cat.
    Stink Eye Mob #87
    Bye bye Bimmer
    Hellooo '11 REX
  13. #28
    Mar 2004
    LI NY
    Quote Originally Posted by xFalleNx View Post
    Do you know why if I prime it twice before I start it no smoke comes out?
  14. #29
    Nov 2010
    Moorestown, NJ
    In other news, I'll gladly take that intercooler off your hands.
    Stink Eye Mob #87
    Bye bye Bimmer
    Hellooo '11 REX
  15. #30
    Nov 2010
    Moorestown, NJ
    Quote Originally Posted by TurboWill View Post
    Honestly, no I do not.
    Stink Eye Mob #87
    Bye bye Bimmer
    Hellooo '11 REX
