Thank you i will try to get make and model of parts...and thanks for info on the electrical system ill do that today..thanks everyone for the help
This is a discussion on PLEASE HELP CANT FIGURE OUT.... within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Originally Posted by mycologist the guy has been heckled enough. Agreed.. now I feel bad. Sorry 03subi!! What I'm trying ...
Sorry 03subi!!
What I'm trying to get at is that the we need to know the make and model of the parts before we can really know what's going on. You need to get that information from the previous owner, otherwise it's going to be difficult to figure out what's going on without ripping everything apart and searching part numbers to figure out what you've got. It sounds to me like the previous owner screwed up the car, couldn't figure out how to fix it, so he decided to unload it on someone else.
I do think there is an issue with the clutch and/or flywheel. Any flywheel under 10-11lbs will most certainly cause problems, but that still does not explain the lights dimming and engine shutting off. The only reason the lights would dim would be because voltage in the electrical system is dropping. This shouldn't happen with a normally charged battery. It could be your alternator isn't charging the battery, it could be that the battery isn't holding a charge, or it could be a loose connection in the electrical system or a short.
The first thing I would do right now is take the car to a local auto parts store, like O'Riley's or Autozone and have them test your alternator and battery (they should do it for free). If that checks out fine then go on the hunt for loose connections starting with the main wires at the alternator and battery, then check all the connections that could have been messed up while changing the clutch.
Problems in your electrical system could easily cause the car to run rough, buck, and stall. And it kinda makes sense that it would get better as it revs up because the alternator is able to put out more juice at higher rpm.
does it die when your driving down the road, or when your pulling out and in first going slow?
When im in first and start to take off it starts to shake and feels like it will die til i push the gas and it pushes through it
OK so that sounds like clutch shudder or chatter. It could be an aggressive clutch, a light flywheel, a worn clutch, or any combination (all, or any two etc.).
Does the CEL come on?
Ok man thanks after i fix electrical stuff i will start that
No cel either
OK then that at least implies (but doesn't prove) that there is no misfire due to, say, the lightened flywheel. So what you could be seeing is drivability issues from one, two, or all three of the sources above. Not unreasonable to conclude this I don't think.
However something you said earlier makes me wonder: the bolt to the starter hangs out? One reason to remove the starter is to remove the gearbox, say for replacing the clutch etc. There is no reason the bolt should not fit correctly though. Either the bolt is incorrect or something is installed incorrectly. I'd find out what that something is and see if that something could cause the shuddering you're seeing now.
Turbo lag would happen all the time if tht was the problem and its not...when i mash on it it ****s and get
