My car siezed up when after accidentally red lineing, any advise - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 24 of 24
This is a discussion on My car siezed up when after accidentally red lineing, any advise within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; i replaced the bearing belts, heads, and gaskets, along with the water pump, should i still run it easy for ...
    Aug 2012
    Greeley
    i replaced the bearing belts, heads, and gaskets, along with the water pump, should i still run it easy for the first 1000
            MainFrame's Avatar
    Austin, TX
    You need a professional tune.. but to run any turbo other than the stock turbo you will need larger injectors and a better flowing oil pump as well as the tune.
    If you put the stock td04 back on then you will just need a stage two tune. Even your exhaust mods need to be tuned for, but at least with that you can get away with using an off the shelf map, either from Cobb or a reputable OpenSource tuner.
    So neither the rings or the oil pump were replaced? I suppose you could get away with that as long as there was no damage to the old bearings that were taken out. If the old bearings were damaged then the rings, oil pump, and oil cooler would need to be replaced. If you failed to replace those the engine would just go again because there will be little bits of metal in there that will clog oil passages and ruin your new motor.
    Registered User rudeboi0427's Avatar
    Aug 2012
    Killeen/Ft. Hood, Texas
    Just curious about the whole ring thing, how do you know if one is damaged? I know the ej's making a lot of ticking noise so I'm just curious if it just ticks a lot more or what?
  6. #19
            MainFrame's Avatar
    Austin, TX
    A cracked ringland will cause loss of power, smoke, low compression, and eventually.. death.
  7. #20
    Aug 2012
    Oh ok. I'm always pretty paranoid with my vehicles so just wanna know. Thanks
  8. #21
    Oct 2005
    Late Devonian
    Merged and moved.
    OP - please start only one thread on a topic.
    Sorry to hear about your car.
  9. #22
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
  10. #23
    Dec 2011
    Pottstown PA
    sorry to hear about the bugeye goodluck
  11. #24
    Oct 2005
    Late Devonian
    To start with get a code reader that will actually read the code.
    You didn't actually reset the ECU by just disconnecting it - you have to disconnect it and step on the brakes to draw the last power out. Do that too.
    See if it starts then.
    It does sound like a possible ECU or more likely electrical issue, or very good chance it is toast.
