Rattle in neutral...
Results 1 to 10 of 10
This is a discussion on Rattle in neutral... within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Today I felt like driving home with the music off. I heard a rattle coming from the shifter when stopping ...
    Registered User CaQuin's Avatar
    Jan 2012
    Queens, NY
    Today I felt like driving home with the music off. I heard a rattle coming from the shifter when stopping at a traffic light. I was on neutral. AC was on... Should I be concerned!?
    Jan 2012
    Queens, NY
    Btw... The rattle is for maybe 2 seconds and only sounds when I'm coming close to a complete stop on neutral. It seems like it shows after a long drive.
    Jan 2012
    Queens, NY
    Anyone? I feel so lonely now
  5. #4
    Registered User KRowe's Avatar
    Nov 2011
    Mattapan
    Could you please record the rattle?
    Drive Hard, Stay Driven..
  6. #5
    If it goes away when the clutch is pressed down suspect the throw out bearing. Otherwise suspect the shifter, or debris, or loose rubbish. I've listed things in order of cost from most to least.
    - Al Stewart
  7. #6
    Jan 2012
    Queens, NY
    Quote Originally Posted by KRowe View Post
    I will try later when I get to record it.
  8. #7
    Jan 2012
    Queens, NY
    Wait a minute. Thats something else now, when I press the clutch down on a stop the engine gets quite. When I release the clutch, I hear more engine...
    Forgive me as I am a noob but what is a throw out bearing?
  9. #8
    Don't consider engine noise, consider a rattle only. If the rattle goes away when you press down the clutch pedal, it could be that the throw out bearing, a release bearing for the clutch mechanism, is faulty.
    - Al Stewart
  10. #9
    Jan 2012
    Queens, NY
    Hmmmm is the rattle suppose to be faint or noticeably loud? The funny thing is that I grew accustomed to the loud engine. So when I heard the engine get quieter when clutch depressed on a complete stop on neutral, I thought that was normal... Does anyone have the same thing on their car?
  11. #10
    Nov 2011
    Mattapan
    For me it depends on how warmed up the car is and the ambient air temp. On very cold mornings when I first start the car the idle RPM in neutral will change between clutch engaged and disengaged. I suspect this is because the flywheel/clutch is still being connected to the motor and spinning even though there is no gear engaged. However this is simply a hypothesis based on what I know about manuals; I am in no way shape or form an expert on these things.
