Gear/transmission oil change question.
Results 1 to 15 of 25
This is a discussion on Gear/transmission oil change question. within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; My 04 WRX wagon has been neglected due to my kids getting all the attention. I've owned the car since ...
    Registered User burgerboy's Avatar
    Aug 2003
    I've owned the car since new and rarely drive it hard. It has ~58K miles, and I'm getting ready to do a bunch of maintenance items. (Plugs, fuel filter, trans/diff oil).
    In doing researching, I've decided on using the Subaru Extra S. My understanding is I won't need more than 4 quarts (or liters) if doing the transmission drain/refill. Is this correct? Best price I've been able to find is a 4 quart package from 42 Autosports. I'm a bit confused on what should go in the rear diff. From what I can gather, the Extra S isn't required, and is probably overkill. If so, what's a good, inexpensive alternative?
    Lastly, since Extra S is synthetic, are there any concerns with putting that stuff in my transmission, which hasn't seen any new fluid for its entire life?
    Any tips for a newbie doing this for the first time will also be greatly appreciated!
    Thanks in advance.
    J
    2004 WRX PSM Wagon
    Mesh hood scoop and grille
    2005 Kawasaki Ti 636
    Extra-S is a great fluid to use in the gearbox. I believe your transmission requires 3.8L of fluid.
    While you're doing fluids, it would also probably be a good time to do your rear differential fluid, as well. A lot of people use Extra-S in that, too.
    Resident Tuner @ WTF Tuning
    Registered User shadowpr's Avatar
    Jan 2011
    TX, NY
    i use extra s in both.
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Yep. WRX 5-spd takes a gallon (3.8L). Extra S is great. I've never been happier with my fluid (Matthew knows).
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    Aug 2003
    Thanks all. Off to search for best pricing on Extra-S!
    J
    2004 WRX PSM Wagon
    Jul 2012
    Let us know where you find it, I need to do a full fluid change too.
    Jan 2011
    TX, NY
    There are a few places that sell it for 15 per quart
    Aug 2003
    Can someone verify whether an 04 uses a Torx70 or a regular socket?
    Seems to have some conflicting info from this thread:
    DIY: Transmission Fluid Change
    J
    2004 WRX PSM Wagon
    zax
    zax is offline
    Nov 2008
    Quote Originally Posted by burgerboy View Post
    Just crawl under and look! The transmission drain plug was changed in mid 2004 IIRC
    Facebook me here
    Jul 2012
    Quote Originally Posted by tebriel View Post
    Is that really the bottles it comes in?
    Yes.
    Jul 2012
    and wow is it expensive, 15 a quart and then 11 for shipping on each. Too late to call, but does the stealership normally stock it?
    Depends on your dealer. Call locally first. They make money on the stuff certainly. I don't use it for cost reasons alone.
    As said, it's dealership dependent whether they will sell it. Mine sells me 4 quarts for $35.
    Jul 2012
    What's the non-synthetic recommended for trans and rear diff?
