Page 2 of 2 FirstFirst 12
Results 16 to 20 of 20
This is a discussion on Torn CV joint boot? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I've replaced the boot a couple of different times with terrific success (kit from NAPA ~). Remember to put the ...
    Registered User silver03's Avatar
    Jul 2003
    10000 Lakes
    I've replaced the boot a couple of different times with terrific success (kit from NAPA ~$20). Remember to put the bearings back in the same spot they came off of if its an inner boot tear.
  2. #17
    Jul 2012
    UPDATE: the transmission mount method works well. Unbolt the 4 bolts holding the mount to the tranny, remove the spring pin from the axle, shove trans away from axle using whatever method you can think of. I bet jacking it up a tiny bit is probably the easiest. Axle should drop right off of the trans splines.
    This will for sure not work for 05+.
    My huge challenge was that my axle was seized up in the hub itself. PITA, real PITA. Ended up having to get an air hammer and pound that mofo out.
  3. #18
    Mine was seized also and was not fun.
  4. #19
    Registered User pizzazombie's Avatar
    May 2011
    Keller, TX
    Thanks for the help, guys.
    Sadly, I already paid to get it fixed. But I'm not too upset. It wound up being like $258 at the Midas near me. Part of me wishes I would have waited to try it myself, but from calling around, I got the impression that this was a pretty good price. Either way, I'm just happy it's fixed.
  5. #20
    Jul 2012
    If I had known it would've been this much pain I would've paid the 200 to have someone else do it. With the parts and the new tools I had to buy, it's not going to be much cheaper than that anyway.
