Results 1 to 7 of 7
This is a discussion on 2002 WRX - Passenger side window won't budge with either switch within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Actually the window twitches just a little periodically when I try to lower it, but neither switch works to lower ...
    Jul 2012
    Actually the window twitches just a little periodically when I try to lower it, but neither switch works to lower it like normal. Is it just a motor swap?
    I need a DIY on this! Oh I just bought this car last weekend and I knew what I was getting.
    Thanks.
    Nov 2009
    Have you tried trying to help it move downwards?
    Jul 2012
    No not yet. I can try that. I wish this forum had sections for each generation of WRX. It's hard to find '02 specific maintenance issues.
    zax
    zax is offline
    Taco Boy zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Yeah might need a new motor. Also might need the switches cleaned. My pass side window can't be rolled-up from the passenger controls, but it can be from the driver's controls. It's unlikely that both would be affected at once.
    Facebook me here
    Jul 2012
    The motors are around $100, so I hope I can figure out if it is indeed the motor before dropping the cash on one. Thanks.
    Steve
    Jul 2012
    What does the regulator do and does anyone know how to tell which one I might need, the regulator or the motor? Using the switches makes the window twitch a little but it won't come down all the way.
    Jul 2012
    Bump. Right now the passenger window doesn't move or twitch when actuating either switch. Hey I made a rhyme.
