Page 4 of 6 FirstFirst 123456 LastLast
Results 46 to 60 of 83
This is a discussion on How to prevent ringland within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; And you can datalog with the Cobb right?...
  1. #46
    Registered User SubiEj255's Avatar
    Jul 2012
    Baltimore
    A car is only as good as its driver
  2. #47
    Quote Originally Posted by FlySense88
    Yes:
  3. #48
    Jul 2012
    Baltimore
    Nice. Seems a little complicated tho but I'm sure I will learn it
  4. #49
    Registered User zefram47's Avatar
    May 2012
    Pasadena, MD
    Just to clarify, I wasn't saying to stay away from OS tuning in general, like Cobb. I was referring to the tools that allow you to monkey with tuning parameters yourself, as doing so without knowing what you're doing could easily cause damage to your engine. Still, I found the article informative. Can't say I won't change my mind, but for now, I'm going to stick with a stock powertrain until the warranty is out. Good luck, whichever route you go! Personally, I love the stock power, but I'm coming to an STi from the Legacy. Every time I drive my Legacy, I'm reminded why I bought the STi.
  5. #50
    Quote Originally Posted by zefram47
    There are OS base maps just like there are Cobb base maps. OS and ATR both allow you to modify maps, so an overzealous laptop monkey can just as easily blow their motor by tinkering when they shouldn't be. The big difference (shy of SD tuning, which isn't applicable on mild setups, and wouldn't likely be implemented by one of said laptop monkeys) is whether you want a proprietary device or a laptop as a flash medium.
  6. #51
    Jul 2012
    Baltimore
    So I'm tryna understand this tuning thing. So I'll have a million questions to keep my car safe.
  7. #52
    Jul 2012
    Baltimore
    Quote Originally Posted by oguitar View Post
    Use a good quality oil and get a good quality tune. That should be it.
    Just wondering. Is the ots Cobb tunes classified as a good quality tune?
  8. #53
    Quote Originally Posted by SubiEj255
    It's a base map; one-size-fits-all solution to EM. Some cars take the map well, some don't. You won't know until you flash it on your car and datalog. As a general rule, Cobb puts out an alright map.
  9. #54
    Jul 2012
    Baltimore
    Ok so I my car don't like it then what? Get a tune for my car?
    Also I've been seeing that most of the Cobb OTS maps are for 91 octane. We use 93 here in MD how would this effect the tune?
  10. #55
    zax
    zax is offline
    Moderating the World! zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Quote Originally Posted by SubiEj255 View Post
    Cobb has maps for 91 and 93 octane.
    Facebook me here
  11. #56
    Contact Cobb and have them fix the problem. You're paying for their support of their product, as well as the IP behind the device/maps. If that doesn't work, look to a third-party for help remedying the situation.
    It would provide a bit of a detonation buffer, as the map will be detuned a bit to run on the lower octane. You wouldn't be the first person to do that as a safety net.
  12. #57
    Jul 2012
    Baltimore
    Ok i see, now with a detuned tune I wouldn't be getting the full "effect" of it would I?
    Ohhhh I didn't know this. I'm just getting my questions out the way before I get so I kno what I expect. Make sense?
  13. #58
    The car is held back a bit due to the decreased knock resistance 91 offers vs 93. Running 93, you're still detuned a bit, but you have the knock buffer at hand.
    Picture you are playing baseball with your nephews at a family gathering. They're all around 12 years old. Are you going to be throwing 80MPH heaters at them, or will you dial it back a bit to something they could actually hit?
  14. #59
    Jul 2012
    Baltimore
    Ahhhh I see what you mean. You my friend are extremely helpful. So it wouldn't be a bad idea to be on a safe side then.
    Once the ecu is reflashed the warranty is practically gone correct? If i were to return it to stock, SOA can see that can't they
  15. #60
    Jul 2012
    Baltimore
    Old thread I know, but will a step or two colder plugs help prevent ring land?
