How to prevent ringland - Page 2
Page 2 of 6 FirstFirst 123456 LastLast
Results 16 to 30 of 83
This is a discussion on How to prevent ringland within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Originally Posted by JStevens 255 is the N/A engine, 257 is turbo'd Sent from my GT-P3113 using Tapatalk 2 Ok ...
    Registered User SubiEj255's Avatar
    Jul 2012
    Baltimore
    Quote Originally Posted by JStevens View Post
    Ok so that means the sti and the wrx have the same motor then?
    A car is only as good as its driver
    Moderator Donkey's Avatar
    Da boonies,Va
    Quote Originally Posted by FlySense88 View Post
    Anything?
    See post #2
    The N/A is the EJ253. The EJ255 is used on the Legacy GT and WRX. The EJ257 is used on the STI.
    2002 FORESTER S
    1998 FORESTER S
    Jan 2011
    S/W Columbus, OH
    Correction accepted, brain farther on my part.
    Yes, the 253 is the N/A engine
  6. #19
            MainFrame's Avatar
    Austin, TX
    See post #2
    ^this
    The problem is with the design of the piston. The ringlands are weak. The only way to strengthen them is to replace the piston.
  7. #20
    Jul 2012
    Baltimore
    ^this
    So they're stronger in the EJ255 vs the EJ257?
  8. #21
            MainFrame's Avatar
    Austin, TX
    I don't know if the pistons in the ej255 are really any stronger or not. The pistons are the weak point in every turbo charged ej series motor.
  9. #22
    The newer STis have adopted the much-touted hypereteutic pistons; Subaru made a big deal of this before voices in the wilderness cried out, suspecting that a bug was reinvented as a feature.
    From my view the new pistons were the right move to make, but not because of their strength. They are intended to reduce emissions, and that's far more important (though I admit if one's car has a blown piston the finer points of clean air design are harder to appreciate...).
    Still, more cars run than don't, so more cars pollute than have blown pistons and the overall concept is not unsound.
    Now, as to whether something can be done to prevent a failure, I suppose the first thing I'd do is leave the car alone provided the factory map is adequate. The failures seen I don't think could have been prevented on the stock cars; on modded cars maybe they could, maybe not, but the owner is paying anyway.
  10. #23
    Jul 2012
    Baltimore
    See I didn't know EJ's has weak motors. Hmmm thats kinda sucks balls
  11. #24
            MainFrame's Avatar
    Austin, TX
    It ain't a 4G63, that's for sure. I wouldn't trust a stock ej series motor past 380whp, and anything over 27psi boost has the potential to crack cylinder walls.. I've put probably over $12,000 into my ej, and I'm still limiting boost to keep the power and strain on the engine down.
  12. #25
    Jul 2012
    Baltimore
    Wow... A 4G63 is which motor?
    Why does everyone praise the ground that subarus walk on, if they have soft motors? The stats you listed aren't bad, but to see stock motors fail is pathetic.
    Everyone always say, "Subarus are so reliable, this & that", but is this true? If you have to change your oil every 3k miles, but you can't use x brand of oil. You have to check your oil every day almost. Even after this is complete, you can't still have a failed motor. Is this reliability?
  13. #26
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Motor in Lancer Evo/Gallant vr4/eclipse gsr/starion esi.
    There's a big difference between a reliable motor at stock power levels and a motor at 400+whp. EJ series motors are very reliable at stock power levels. But it is an aluminum block with cast pistons. The 4G63 has an Iron block and forged pistons (which does not pass recent emissions laws).
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
  14. #27
    Da boonies,Va
    ALL motors have their issues. Lets take the 4G63 as an example. The 7 bolt version had crank walk issues. If you think Subaru is the only manufacturer to have motor fail then you are being naive. As far as the oil is concerned I run mine between 5k-7.5k miles on full synthetic. If you enjoy dumping money down the drain then sure,change your oil at 3k. This is my opinion, but obviously following the manufacturer's recommendation for a car in warranty is required. But if you are voiding the warranty anyways then there is no reason to stick with it. Sometimes the facts are the needle deep in an opinion haystack but thats they way the world is. A UOA is the only way to tell if your oil and filters are doing what they are supposed too. So far my Subaru seems pretty reliable. 190K on the original motor and tranny running 20+ psi on several different flavors of turbos. I just recently had to change the factory halfshafts and ball joints. Reliability is also subjective. Is my car reliable or am I just lucky? The biggest variable for "reliability" is the owner/driver in my opinion. Doesn't help when people run around putting 87 or 89 octane in because they can take the time to read their owner's manual and understand the information or do clutch dumping donuts and then complain about "reliability".
    2002 FORESTER S
    1998 FORESTER S
  15. #28
    Jul 2012
    Baltimore
    That's great that YOUR car is. I like to hear stories like this. I never knew the reliablity factor of the older subies b/c i don't have one. So maybe the older ones are more reliable than the newer ones.
    Yes there is a huge difference, but what's the reasoning for cars with stock motors failing? Drivers error? I mean with a soft metal like aluminum its guaranteed to fail sooner or later.
  16. #29
    Oct 2005
    Late Devonian
    Well yea but I'm saying without dropping in a built motor.
    You don't have to even split the case.
  17. #30
    Oct 2005
    Late Devonian
    This is just internet hysteria leading to paranoia. People don't make threads about "my car didn't break" usually.
    Click the arrow in the quote and read the whole thread.
    Quote Originally Posted by nismopowerdqg View Post
    186,300 miles and still running strong. ive been stage 4 for about 85000 miles
