Maintenance at 100k miles?
13K views 4 replies 5 participants last post by  SD_GR
#1 ·
What maintenance is usually performed at 100k miles for a 02 wrx? Also when is the timing belt due for a change?
#4 ·
Timing belt is usually done around 105k. Should also take care of the water pump, thermostat, tensioners and that jazz while you are in there. Oil change, tranny fluid, and differential fluid changes also should be done at that time.
