Results 1 to 4 of 4
This is a discussion on Fuse issue - LED KIT - 2012 WRX within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I have a 2012 wrx. I am hooking up an led kit and want them to turn on when the ...
    Registered User dloring's Avatar
    Jan 2012
    long island, ny
    I have a 2012 wrx. I am hooking up an led kit and want them to turn on when the doors open.
    Which fuse do i need to plug into? Does it have to be the fuse that the dome lights are on? If so, what number fuse is it?
    zax
    zax is offline
    Taco Boy zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    I would consult the fuse map specific to your vehicle. One consideration: the light control (door open; light on) is likely controlled AFTER the fuse box meaning that the LEDs may not act the same way as you hope (since you can still turn on the dome light with the doors closed). You may have to end up splicing into the dome lighting switch.
    Facebook me here
    Jan 2012
    long island, ny
    thanks. the car manual was no help.
    The kit calls for the LED kit's ground wire to be attached to the dome light ground wire by the door switch (they say this will allow an open door to turn on the lights), which i did, and the power to be connected to a fuse via an "add-a-circuit". the "add-a-circuit" needs to be inserted into a spot which has a constant power source. That is where i am stuck. i figure whatever fuse the dome lights where on was my best bet.
    Mt. Laurel, NJ
    Quote Originally Posted by dloring View Post
    The negative ground wire will be what controls it turning off and on, ergo why it should be connected to the dome light switch. The power needs to stay constant, so connect that to the positive power wire of the clock pod or something like that (or look for the constant power wire behind the stereo...usually red or yellow).
