There should be a sticker with system capacity visible. However, I recommend that you address the fault first. Put some gauges on it and get annual and see what pressures you have vs. what you should have. Then find out why and fix it if need be.
This is a discussion on AC charge... within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I just replaced the tensioner for the AC system, now that I know it SHOULD be working I'm only getting ...
I just replaced the tensioner for the AC system, now that I know it SHOULD be working I'm only getting warm air out the vents... how much refrigerant should I get for this car and what kind? Is there any other specifics I should know before doing g the recharge?
Car is a 2002 wrx...
Sent from my Galaxy Nexus using Tapatalk 2
Thanks, Mike
My suggestion is that if you don't know these answers already, it would probably be a good idea to take the car to a professional. You probably have a leak somewhere and they have the equipment to properly diagnose and repair the system
Stink eye mob #727
2011 WRX DGM Hatch, Protuned Stage 1
Yeah I know, just didn't really want to spend the cost for that if I didn't have to... but wasting the money on a charge that won't stay is just as bad....
Thanks, Mike
Hawkeye Alliance #1050
Build Thread
http://i1108.photobucket.com/albums/..._Signature.jpg
Always dirty, never scurred......
Very valid point, thanks
Thanks, Mike
Hawk-Eye Alliance #Eleventy,000,000,000|N.E.R.D. Member 20,000
Stable: 07 GMC 2500HD, 06 LGT, What's left of an 04 STI, 03 WRX, 98 RS, 86 Brat
Resident Clubdub Debbie Downer. I'd love your ideas if you kept them to yourself. Subarus suck, get a new wife.
hey there buddy this is my opinion on your situation about 2 weeks ago i had warm air coming out so figured id check for leaks
first and i as you didnt want to pay somebody to do it. i went and got some a/c refrigent that has a green dye in it to detect leaks that will become visible
obvisously from where ever the leak is.i got that and the hose(with gauge attached so you dont overfill)to hook to my low press side. and in about 2 days i saw the green dye
it was leaking from the hose that comes from my condesner to my a/c unit.all in all i spent about 25 bucks to find the leak
i replaced the hose with a genuine brand new subaru hose and my ac has been working fantastic its very nice and cold
this is my 2 cents
See I don't mind the cost to get the equipment if its some thing I can use on both my car and the wife's. I don't need it for hers but who knows in the future... I think I'll start by trying to do it myself and if I can't figure it out in a weekend or so then take it to the shop... I've spent more on ammo for a day than that and that's a one time use item...
Thanks, Mike
To fix a leak - if there is a leak - correctly you will need to pull a vacuum before recharging the system. Also one way to make sure that you have the correct amount of refrigerant is to keep gauges on the system so you can keep an eye on pressured and put the container with refrigerant on a scale, do you can see how much is being added as the container gets lighter (the spec sticker uses the nauseating units "ounces" but that's life). So all this stuff costs money. I'd beg/borrow before buying.
Yeah I can borrow some stuff and if need be rent as well...
Thanks, Mike
I have a $5000 a/c machine that allows me to fix an a/c system correctly. Air conditioning is not something you just shoot with some r134 and call it a day. Its blowing hot air because it needs to be repaired and in order to repair it properly, you need the right tools. That's why I suggested to take it to a professional. There are certain things that are DIY, a/c just really isn't one of them.
Stink eye mob #727
I understand that, and appreciate the advice, but paying a shop say $200 for them to diagnose a leak or spending $50 to find the same result myself doesn't really make sense... if there is an eminent problem I can have a shop address it then. But to start I can try the easier and more cost effective route... right?
Thanks, Mike
As was pointed out before: it needs to be cavuum pulled before charging. Given the age it could probably do with a flush and clean, too. And it may need to have the restrictor replaced. I suggest you can to SOME of the grunt work: fill the system with the leak indicating stuff, see where it leaks. Replace leaking parts. By then you absolutely have air and with that humidity in the system. Air and humidity are KILLERS for A/C systems. Do not run that unless you're planning on replacing the compressor afterwards anyways. At this point it's time for a shop. They can replace the restrictor (often just a insert or "dent" in the line, right before the evaporator) That's cheap and it's where any built up dirt collects and eventually plugs the line. THey usually want to replace the dryer/tank unit, given 10years its probably good to do. Not sure what a flush would cost, but for the future of the compressor it would be advisable. They'll pull it into hard vacuum and hold it to see if there is still a leak. Only then is it time to re-fill with refrigerant and oil. There is oil for the compressor in there, just thought I might mention that also. Now you have a A/C system that works and hopefully stays that way.
OK that explains and makes more sense of why not to do it myself. Thank you.
Thanks, Mike
