seatbelt pretensioner bad or not?
Results 1 to 11 of 11
This is a discussion on seatbelt pretensioner bad or not? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; How can you tell if the Pretensioner is bad or not? My drivers seat belt is bad it does not ...
    Registered User SQ-REX's Avatar
    May 2002
    wisconsin
    How can you tell if the Pretensioner is bad or not? My drivers seat belt is bad it does not lock and the springs are toast so that one i am sure. Passenger one will lock in place when you tug on it fast, is that one still ok? BTW this car was a wreck ive been rebuilding for a hobby project.
    thanks
    May 2002
    wisconsin
    You know reading this I probably answered my own question but I really not 100% sure lol
    I agree you probably answered already. A very conservative, highly safety-oriented view is to change all safety equipment after a wreck. People replace air bags but nobody that is not required to do so legally replaces the seat belt assembly. I suspect they should.
    If the car was in a wreck, there was almost certainly a driver in it, so the driver's seat belt assembly has been through a wreck. If it's malfunctioning, change it, because you'll be relying on it for your life.
    Registered User Ingo's Avatar
    Mar 2012
    Colorado Springs, CO
    +1 : There is a certain amount of strech built into the seat belt material. If it's been crashed with load (like a driver and/or passenger) the belt should be replaced by default. Even if it seems to be working perfectly well. In the next crash it would probably hurt a person due to having no give whatsoever. BTW the pre-tensioner is onther part: it's a the bottom of the inside whip, the one the seat belt buckles into. The part acts as a "reverse" spring and is to take up the slack that may be there due to people not sitting fully in the seat back and or moving about in their seat. Therese thingys have often pressure cartridges like the air bag, once used they have to be replaced... nto sure if that's in the Subies and what years...
    I think VAG had interesting solutions, with procon ten on the 80 that used suspension cables to pull the belts tight when the motor moved during a crash, and then using a... Wankel (sigh...) to create pretension in later models.
    In any case I'd change even simple belts, at least the driver's side. Maybe find belts from a car with a blown motor, not a wreck if you want to go used parts instead of $$$ new.
    ¯\_(ツ)_/¯ Rambo's Avatar
    Oct 2010
    Portland, OR
    ...a... Wankel (sigh...)
    You mean a rotary, right?
    2007 Outback 3.0R wagon
    I need an aspirin...
    May 2002
    wisconsin
    I want to be save first and foremost, however they cost $69 each to rebuild and i doubt that they would tell me if it was bad or not and just take my money.
    thanks all
    Oct 2010
    Portland, OR
    Quote Originally Posted by SQ-REX View Post
    thanks all
    Forgive me, but why on earth would you want to rebuild safety equipment? $69 is nothing compared to getting thrown from a vehicle, spending months in the hospital, plus many more in therapy, assuming you survive in the first place. Saving cost? I think you just did.
    EDIT: Wait, you meant to say "safe", not "save", right? In that case, sorry for the rant.
    May 2002
    wisconsin
    I did mean save $ but still safe. body shops order rebuilds all the time by sending in the bad ones for cores charge. the body of the unit is all that is left when they rebuild them, it gets new belt, pins and whatever else.
    I however am NOT going through a body shop, and I have a place to send them. I figured out what I need now Thanks All for the help
    May 2002
    wisconsin
    how ever if anyone has a video or directions on how to change out the passenger airbag that would be awesome!
