Results 1 to 7 of 7
This is a discussion on Transmission fluid ****tail within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I've just purchased a trans fluid ****tail for my 02 bugeye. Question: Is this something that should only go into ...
    Jul 2007
    I've just purchased a trans fluid ****tail for my 02 bugeye. Question: Is this something that should only go into my car after the old fluid is flushed? Or can I just add it to what's in there now? There isn't much in there now BTW.
    Jul 2004
    Seattle, WA
    Manual transmissions can't be flushed. Drain, and fill. That's it.
    What do you mean there isn't much in there now? Is it leaking? The c0cktail will not fix leaks.
    Jul 2007
    Quote Originally Posted by SeattleJeremy View Post
    Yes, I meant to say drain and not flush. Can I just put the new fluid in without draining the old fluid.
    I don't know if there's a leak, but the level is very low, down below the L mark.
    Texas, United States
    Mine will go 30,000 miles without moving a hair on the dipstick, so I would guess you probably have a leak somewhere. Does your car stink like cat piss? Gear oil has a pretty distinctive smell..
    Jul 2004
    Seattle, WA
    You can't mix the c0cktail properly unless you drain the transmission first.
    Find the leak, and fix it first. It doesn't matter where the leak is, the fluid will have to be drained to fix it.
    Maybe it's as an axle seal?
    Jul 2007
    Okay thanks, I guess I'll take it in to have it looked at.
    Jul 2007
    No smell really.
