Interesting Noise
Results 1 to 15 of 17
This is a discussion on Interesting Noise within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Okay guys I have a problem. I keep hearing a noise and I cant figure out where it is or ...
    Registered User ArkySTI88's Avatar
    Oct 2011
    Arkansas
    Interesting Noise
    Okay guys I have a problem. I keep hearing a noise and I cant figure out where it is or what is causing it. I'll try to explain it the best I can.
    So when I'm driving you cant hear it, but anytime I left of the accelerator you can briefly hear it between 2300-2500 rpm. It only occurs then and if I dont have the gas pedal in or the clutch in. It happens in any gear but it is the loudest in 4th. The noise itself is definitely metallic (of course) and it kind of sounds like something rubbing against something else.
    Thats the best way I know to describe it. Any ideas would be awesome.
    Alex
    2005 STi
    1968 AMC AMX
    1964 Chevrolet Corvair
    Blobeye Syndicate #479
    ClubWRX.net Vendor adam@kronosperformance's Avatar
    Nov 2005
    Princeton, NJ
    Heat Shield maybe? Did you cut it or replace it at any time?
    May 2007
    orlando flawduh
    Yup maybe heat shield or exhaust hangers
    desiree
    Oct 2011
    Arkansas
    Might be the exhaust hangers. I didnt touch the heat shield when i replaced the DP. Didnt think about the exhaust hangers though.
    Alex
    2005 STi
    1968 AMC AMX
    Moderator rage-wrx's Avatar
    Aug 2010
    Yonkers/NYC
    You used the stock heatshield when you replaced the DP? I thought you had to cut the stock heatshield to get the aftermarket DP to fit.
    T0ny
    2011 WRX
    2012 FXT
    The Big 2011/2012 Mod Thread
    May 2007
    orlando flawduh
    Maybe he had an aftermarket heatshield to begin with? Idk. You definitely can't use the OEM one
    desiree
    Oct 2011
    Arkansas
    On my lunch break I will take a picture of my engine bay. Granted I got my STi used. I knew what had been done to it and the guy had put it all back to original when he traded it in. If there is something I need to do I definitely want to know cause I dont want to mess anything up.
    Alex
    2005 STi
    1968 AMC AMX
    Oct 2011
    Arkansas
    Okay here are my photos. Sorry if they arent clear. Hope it helps. Thanks for the help. Still learning about my STi.
    Alex
    2005 STi
    1968 AMC AMX
    Aug 2010
    Yonkers/NYC
    Well that makes it certain that it is not the heatshield. There is no heatshield.
    T0ny
    2011 WRX
    2012 FXT
    Oct 2011
    Arkansas
    Haha. That is what I was thinking. Ive slept since I replaced the DP so I couldnt remember. Been a while since I've looked under my hood (I know thats sad).
    Alex
    2005 STi
    1968 AMC AMX
    May 2007
    orlando flawduh
    Invisible heatshield is invisible
    desiree
    Oct 2011
    Arkansas
    Quote Originally Posted by wrxtreme06 View Post
    My main concern is I dont want to tear something up and the noise is rather annoying. I didnt replace any of the hangers for the exhaust. Think it might help to change those out?
    Alex
    2005 STi
    1968 AMC AMX
    ¯\_(ツ)_/¯ Rambo's Avatar
    Oct 2010
    Portland, OR
    As a side note, you really ought to have a heatshield in place. Aftermarket shields are only $50, and are far less of a PITA to remove/install than the &$%#-ing OEM one. The shield helps isolate the turbo heat, making the turbo more efficient, and dramatically reducing the chances of heat-soaking the intercooler, especially in the summer.
    2007 Outback 3.0R wagon
    Oct 2011
    Arkansas
    Okay ill definitely get one then.
    Alex
    2005 STi
    1968 AMC AMX
