03 WRX LIMP MODE NO BOOST PLEASE HELP - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 25 of 25
This is a discussion on 03 WRX LIMP MODE NO BOOST PLEASE HELP within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; P0244: overboost. You mentioned you had a boost spike. Basically, the ECU has a limit as to what boost to ...
    P0244: overboost. You mentioned you had a boost spike. Basically, the ECU has a limit as to what boost to cut out at, and you hit it.
    P1088: TGV #1. PS Front. Make sure the connection is tight/secure.
    After checking the connection for P1088, reset the ECU and see if the code comes back.
    Resident Tuner @ WTF Tuning
    Registered User 03_bugeyeSTI's Avatar
    Jun 2012
    Denver
    would the tgv be causing the loss of power??
    Quote Originally Posted by 03_bugeyeSTI
    TGV codes cause the car to go into limp mode. That's why they are disabled when you do TGV deletes.
  6. #19
    Jun 2012
    Denver
    and limp mode limits power and boost??? sorry im new to all this :/
  7. #20
    Yes
  8. #21
    Registered User nateleeg's Avatar
    Mar 2013
    Las Vegas, NV
    I'm having similar problems still.
    Reset the ECU, runs good for a bit then set back to limp mode. When i reset it and it boosts properly, there's a slight rattling noise. Thinking this might be part of the problem, but no CEL's are thrown.
    Also, replacing the catted uppipe tomorrow, hoping this will solve my problems.
    Could cleaning the MAP sensor help?
  9. #22
    Mar 2013
    Las Vegas, NV
    Just pulled the negative battery, drove it for 25 minutes. Limp, just like that. It's driving me mad! Any suggestions?
  10. #23
    Quote Originally Posted by nateleeg
    Do you have TGV codes?
  11. #24
    Mar 2013
    Las Vegas, NV
    No I haven't ran any codes, figured since I'm not getting a CEL I didn't need to. Maybe I should stop by Autozone and plug it in? (I'm still pretty new at maintaining a forced induction motor)
    Also, thinking i might have just had some bad gas, maybe try some octane booster. Start with the little things first, right?
  12. #25
    Mar 2013
    Las Vegas, NV
    It bounces back and forth on it's own, runs good for a while, then sets itself back to a weak mode. I can pull the battery and it will run strong for awhile..until it sets back again. Anyone ever heard of anything like this?
