Results 1 to 3 of 3
This is a discussion on Reverse light switch question within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Can you replace the reverse light switch, part number 32005aa081, without dropping the transmission? Is it a PITA or is ...
    Supporting Member yamaha_rider619's Avatar
    Jul 2009
    colorado is home, Kansas is the temporary home
    Can you replace the reverse light switch, part number 32005aa081, without dropping the transmission? Is it a PITA or is this a straight forward job?
    Josh
    2003 Subaru Wrx Vf39'd
    Bugeye mafia #300
    Sponsored By: WRXPro.com
    Registered User Ingo's Avatar
    Mar 2012
    Colorado Springs, CO
    IDK, but somewhere I got the shop manual for my 08+ in PDF. Look around and see if you can't find this type of info on your model. It's useful for just about anything, you'll use it all the time, just to see how things come apart and are put together...
    Jul 2009
    I did the fix today. Jacked the car up, crawled under, looked at the drives side of tr transmission and saw the bolt and connector not attached. Used a open ended wrench and switched out the parts. FYI when you pull the sensor bolt, fluid will slowly drop out, so do the swap quick. Easy 10 minute fix.
    Josh
    Bugeye mafia #300
