Fuel Smell from the exhaust - Page 2
Results 16 to 30 of 35
This is a discussion on Fuel Smell from the exhaust within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Incorrect! That swaybar is not stock. Also I don't recall the tubs being blue on that model year. Either that ...
    Registered User power091999's Avatar
    Jul 2003
    Incorrect!
    That swaybar is not stock. Also I don't recall the tubs being blue on that model year. Either that or my age is catch up with me. (EDIT: Apparently I am going blind. Those are just covers. Ignore me like everyone else does.)
    If you are down to 1/4 tank I would probably just fill up with 93 octane and drive it easy until your next fill up. That should take care of the issue with poor performance.
    The exhaust smell may be from a possible exhaust upgrade that was brought back to stock, and installed poorly. Maybe without a gasket?
    I would get that checked out though. Other than that I guarantee you will love your car as you become more educated about it.
    You have come to the right place though!
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Quote Originally Posted by power091999 View Post
    Incorrect!
    You are both smartasses.... I was talking specifically about the DOWNPIPE. I can't see the rest of the car
    Besides that's a strut tower bar, not a swaybar. The hydraulic lines were blue from the factory on the 2004-2005.
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    Jul 2012
    Denver area, Colorado
    So, stock is fine with me... I'm no racer. Can someone confirm that it is a stock 2.5 liter turbo? That's what it looks like in comparison with images in the online manual.
  5. #19
    zax
    zax is offline
    Nov 2008
    Quote Originally Posted by natimage View Post
    No. It is a 2.0L turbo.
    Facebook me here
  6. #20
    Jul 2012
    Do you just smell gas when the car is warming up? This may be normal as the car is in warm-up fuel enrichment mode. Is the car a manual or automatic? If an automatic, it will be sluggish regardless off the line. Keep in mind that a Kia Rio will have more off-the-line torque compared to this low-displacement, low-compression motor with a large exhaust restriction (turbo).
    Car is automatic. Sluggishness has increased from when it was first purchased a little over a month ago. Gas smell is not noticed when car is warmed up, but after running and occasionally during slower driving.
  7. #21
    Jul 2012
    Can you tell me how to determine this?? I was basing it on the drawing in the manual, which near the alternator looks like the 2.5.
  8. #22
    May 2007
    orlando flawduh
    02-05 wrxs are 2.0l. 06+ are 2.5
    So unless te previous owner swapped it out, you have a 2.0l
    desiree
  9. #23
    Jul 2003
    TOUCHE! I had owned a 2003.... so im exempt.
    OP: Do you have any more info about the history of the car? How many prior owners... etc?
  10. #24
    Jul 2012
    Ok, I can see where simply comparing to the drawings won't tell me... based on photos online. But... if there is a way to look under the hood and make this determination, I'd be interested in knowing it!!
    Thank you all for the input/knowledge so far! I hope that I am able to continue learning more and more. Would love to make some "real mods" in the future.
  11. #25
    Jul 2012
    Unfortunately, not much. I believe I looked at a free Carfax report prior to purchase and didn't see any accidents or anything alarming. I want to say there were 2 previous owners. One of them didn't put hardly any miles on it, and the other did. I don't recall any other specifics, though.
  12. #26
    zax
    zax is offline
    Nov 2008
    If the previous owner did a 2.5L hybrid build, there would be no way to tell short of pulling the block and checking the code... or you can put your foot down and easily tell the difference .
    Simply put, there was only ONE engine option available for the 2004 WRX, and that's the EJ205. The EJ257 was the STi motor, and this is clearly not an EJ257. Here are notable differences between the later EJ255 and the EJ205:
    EDIT: At some point the fuel filter was moved to the fuel pump location... I thought this was in 2004? Are you sure this is a 2004?
    Furthermore, the "sluggish" feeling of the car is likely the ECU learning the low octane 87 fuel. Likely it is pulling boost and adding timing to protect against detonation. I would fill the car with 93 IMMEDIATELY, then pull the battery leads and step on the brakes for 10 seconds. Then reconnect the battery leads. Your ECU should relearn the new fuel curve quickly.
    Facebook me here
  13. #27
    Jul 2012
    VIN search indicates 2004, as did the dealer. Thank you so much for the information! I won't be pulling any blocks to tell! And as for putting my foot down to tell.. I'll certainly wait to get better gas run through it!! But since I drive a standard Jeep... most anything feels pretty quick to me! Not sure I know enough that I'd be able to tell! I'll just go with 2.0 liter until I learn otherwise!!!
    I'll fill up with the best gas I can find, and follow your suggestions with the battery leads afterward!!
  14. #28
    Captain James of the SS Impreza has gone down with the ship Drews's Avatar
    Aug 2008
    Davey Jones Locker
    You can look between the alt and PS pump and it should be stamped with either EJ25 or EJ20. I suspect you will find EJ20
    Hawk-Eye Alliance #Eleventy,000,000,000|N.E.R.D. Member 20,000
    Stable: 2014 Hyundai Veloster Turbo (Matte Grey), 06 LGT, 98 RS, 16 Crosstrek
    Resident Clubdub Debbie Downer. I'd love your ideas if you kept them to yourself. Subarus suck, get a new wife.
    Never argue with idiots. They'll drag you to their level and beat you with experience.
  15. #29
    Jul 2012
    Ok... I thought asking where I could find 93 Octane was a stupid question... but I'm thinking it might not be. Any advice on where to go in Aurora, Colorado to find 93?
  16. #30
    Jul 2003
    93 is probably a bit more on the rare side I know it's close to impossible for me to find here. If you only have access to 91 that is still much better than 87.
