turbo not spooling correctly.
Results 1 to 9 of 9
This is a discussion on turbo not spooling correctly. within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; i thought it was just my gauge being retarded, usually spools to 15psi but is only goin to 5psi, it ...
    Jun 2012
    wellsboro, PA
    i thought it was just my gauge being retarded, usually spools to 15psi but is only goin to 5psi, it is not even pulling like it normally does, i believe it is a vacuum line, what could it be? and what are the fixes to it? is it hard to fix? easy? i need help please. thank you.
    May 2007
    orlando flawduh
    Car? Year? Mods?
    desiree
    Jun 2012
    wellsboro, PA
    02 impreza wrx, 3" catless exhaust, faze boost gauge, k&n intake, aftermarket BOV (dont know the brand) some ghetto turbo timer (only works as a volts meter).
  5. #4
    Moderator Donkey's Avatar
    Da boonies,Va
    Do a boost leak test.
    2002 FORESTER S
    1998 FORESTER S
  6. #5
    Registered User cjm1991's Avatar
    Jun 2009
    st louis
    Do a smoke test for leaks, I'll bet either intake or bov related. Is the car tuned?
    Chris
    02 Camaro z28 T-Tops, m6 49k miles
    Bolt ons and tuned - 349rwhp/362rwtq
    02 Ws6 T-Top,m6 80k miles
    Bolt ons/Cam/tune - 436rwhp/424rwtq
  7. #6
    Jun 2012
    wellsboro, PA
    just wondering, but since its got to do with spooling how would the BOV effect that? and not that i know of, im still trying to figure out what all the prev owner did to it. i havent had it for long, but am trying to get it too 100%, not stock but fix all its probs.
  8. #7
    ClubWRX.net Vendor adam@kronosperformance's Avatar
    Nov 2005
    Princeton, NJ
    Unless your blow off valve is leaking air (which is possible), it won't affect it otherwise. Your blow off valve is supposed to stay closed as you're building pressure then it opens when it releases air to prevent compressor surge. Basically, the time you're looking to build up your pressure, all its doing is staying closed.
  9. #8
    Jun 2009
    st louis
    Quote Originally Posted by TurboScubi View Post
    It can do exactly as Kronos said, especially being a knock off one. If the car isn't tuned and modded incorrectly I'm sure it could throw it into limp mode as well, I'd do the leak test first.
    Chris
  10. #9
    Jun 2012
    wellsboro, PA
    Quote Originally Posted by cjm1991 View Post
    yeah i suppose i can see where the bov would mess it up. lol. thanks.
