Car turns over then dies
Results 1 to 15 of 16
This is a discussion on Car turns over then dies within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Im not sure what is causing this but i can sometimes get it to run for 10 seconds before it ...
    Registered User ExceedingLife's Avatar
    Oct 2011
    Wi
    Im not sure what is causing this but i can sometimes get it to run for 10 seconds before it kills itself. it usually kills itself right after it turns on so it doesnt run at all only when pressing the gas i can sometimes keep it running longer. I just changed the throttle position sensor and i also got a new mass air flow but nether of these changes solved the issue. Even when i take the maf out the car still dies it does not idle a solid 1 - 1.5k like its suppose to. I tried a different key and still it shuts off.
    It is a 2002 subaru wrx the cel is on tomorrow im going to try to use my friends scanner to see what it says. before it was throwing a maf code but changing that solved nothing
    Apr 2007
    8000' up in Colorado
    What mods and mileage are on the car?
    Without knowing that plus what the CEL code is nobody is going to be able to help you so post back when you have it.
    Scott
    Oct 2011
    Wi
    Knock Sensor
    F1 Racing Flywheel
    F1 Stage 3 Clutch
    Stage 2 (300 H.P.) UniChip
    Xcceleration Short Throw Shift Kit
    Samco Intercooler, Air Inlet and Water Hoses
    GFB Pulley Set
    Triple Headlights
    18" zinik z30 Rims
    225/45-18 Tires
    Turbo back exhaust system w/3.5" tip, includes downpipe, high flow cat, intermediate pipe
    MRT Flex Joint Uppipe
    HIDs
    The computer is turbo XS im thinking that could possibly be a problem and maybe i need to buy a new stock subaru computer and then my car will start again?
    The car has like 101,000 miles
    Tm going to try to check the CEL tomorrow
    Apr 2007
    Is the computer running a tune to support all of those mods? Or is it some kind of standard tune?
    Even if it is tuned, a LWFW is well known to cause ignition issues. When combined with those underdrive/lightened pulleys it can certainly cause issues. Personally I'd get rid of the pulleys because they're not in any way helping you, and go back to a stock flywheel. I'm guessing your codes are going to be misfire codes. You need to read the thread "IF YOU HAVE A MISFIRE CODE READ THIS" too.
    When did this start happening and what changes did you install right before it happened?
    Scott
    Oct 2011
    Wi
    im selling my car so im not going to get rid of the pulleys and i did see missfire codes before, i dont have the stock pulleys or a stock flywheel this just started happening 2 weeks ago, i just got my tranny rebuilt and then the shop took it for a test drive and it was fine then they did a oil change and after the oil change we never got my car started to stay running again...
    I dont think the computer was tuned with all the parts in the car but if it was it would not be of my knowledge because the person i bought the car from did most of the work well had most of the work done from a shop
    The computer is Click image for larger version.
    Oct 2011
    Wi
    I just scanned my car and this is the results
    4 CEL codes
    1: P0102 MAF or VAF A circuit low input
    I just installed a new MAF in my car.
    2: P0113 IAT sensor 1 circuit high input
    3: P0108 MAP/BARO circuit high input
    4: P0244 Turbo/Sup wastegate solenoid A range/performance
    I got the car running longer then ever since this problem started tonight i got it running for about 1 minute. While it was running the car was rocking while idling pretty bad i could easily tell it was misfiring very BAD and the exhaust is making popping / chugging noise also supports misfire seemingly, held the gas down for a moment when first started and then let off after holding around 3000 RPMS then the idle dropped to about 1000 RPMS without dieing for a bit but was still misfiring and then the car killed itself...
    Oct 2011
    Wi
    please someone give me some answers i been trying to do as much as i can to try to get the car running and driveable again......
    FMS
    FMS is offline
    Jul 2012
    Chicago IL
    If you have replaced your MAF sensor and your still throwing the code follow it back to your ECU and make sure the wire is connected well. I have heard of people having similar issues due to electrical connections not being fully seated.
    4. PO244 is from overboosting. A pro-tune would fix this. You could try another OTS Tune (Cobb Accessport with a LWG tune)but I wouldnt recommend it over a pro-tune.
    Feel free to PM us if you have any further questions.
    OPEN 7 Days a week|We match and beat advertised prices and sales|855.447.8288
    AOL Instant Messenger: FlatlineMotorsports.mason@gmail.com
    Link: Flatline Motorsports Online Store
    Link: Flatline Motorsports Facebook
    Oct 2011
    Wi
    The thing abut the MAF though is even if a MAF is completely disconnected your car is suppose to run and idle at 1k - 1.5k RPMS i heard and with my car when i tried this my car still did the same thing it died shortly after it started it would not stay running i was thinking of buying a stock computer for my car and seeing if that would solve the issue
    Engine Computer ECU IMPREZA 807289 02 | eBay
    The wire connected to the MAF is tightly connected to i made sure it wasn't lose.
    Apr 2007
    A stock computer isn't going to solve the problem. You need to have a tune that supports all of those mods. LWFWs are very well known to cause misfire issues all by themselves. If the ECU isn't running a map that supports all of those mods I'm amazing the car was running at all.
    There's no way an oil change suddenly caused things not to work. You have much bigger issues.
    You have several options:
    1. Put stock parts back on the car and return the ECU to a stock map.
    2. Find a tuner to put a custom map on the car designed for all of those mods.
    3. Start going through all of the mods one by one and trying to figure out what exactly is causing the problem.
    Without knowing what tune the car is running, your only real choices are 1 or 2. There is no other solution.
    Scott
    Oct 2011
    Wi
    Ok, Thanks man i will have to get it tuned at a shop called REDLINE i believe then down a hour away. there are no shops around here that can tune my car for me i don't have any stock parts for the car because they were done before i bought the car
    I am now going to try to make sure i know all the parts that are in my car so i can tell the company so they can give me a tune so my car will run again do you have any clue how much it may cost for them to do that for me?? i really hope its not that costly because i plan on selling my 02 wrx to get possibly a 05 STI
    Dec 2014
    Florida
    I'm having the same problems with my '06 Sti. Codes are P0102 and P0113. Tried a new MAF to no resolve. Will check wiring next.
    Any fixes to these problems? I've read several posts regarding these problem codes with no resolution.
    Moderator Donkey's Avatar
    Da boonies,Va
    2002 FORESTER S
    1998 FORESTER S
    Da boonies,Va
    My guess is bad connection at MAF or you have a short. Back probe the MAF connector with a multimeter. You will need the FSM for the MAF pin out.
    2002 FORESTER S
    1998 FORESTER S
    Dec 2014
    Florida
    Weird, my problem was the timing belt. Replacing belt, guides and pulleys. '06 Sti with 120k miles preowned never was replaced. Result of not performing recommended maintenance cost me more $$$. I'm also replacing water pump while torn down. Hope there are no other issues when buttoned back up.
