Well, you can build a tester for your boost system. You can also hookup an air compressor to your waste gate and see what PSI it opens at.
This is a discussion on 05 sti low boost within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Need some help how do you test your waste gate or blow off valve i have all most no boost.:...
Hawk-Eye Alliance #Eleventy,000,000,000|N.E.R.D. Member 20,000
Stable: 07 GMC 2500HD, 06 LGT, What's left of an 04 STI, 03 WRX, 98 RS, 86 Brat
Resident Clubdub Debbie Downer. I'd love your ideas if you kept them to yourself. Subarus suck, get a new wife.
What mods and mileage do you have? When did the problem start? Do you actually have an aftermarket blow off valve or the stock bypass valve?
The best way to test is with a smoke test since you can see any actual leaks.
Scott
Sad to say but yes it all stock expect i have stage 1 on it and it has 880000 miles on it.I think the turbo is bad i was running 17 lbs of boost last time i checked it. Now i have 8 lbs and i have some oil in the intercooler but not alot and its Not smoking.Thanks for the reply
thanks for the reply how much air psi should take to open the waste gate.
Any reason why your ECU is pulling boost? Any lean condition may cause this. 8 PSI is wastegate pressure as you know. Since the stock EBCS is a bleed-type and not an interrupt type solenoid, check to make sure that your restrictor pill is intact and in your boost line.
Facebook me here
Originally Posted by Mikie13
Facebook me here
How long have you had the tune on it? This didn't start happening as soon as or soon after you did the tune did it?
Holy high mileage Batman!
Are you basing your diagnosis that the turbo is bad just based on the oil in the IC? That's perfectly normal to have oil in there. As long as it's not a lot then it's probably just fine, but still worth monitoring over time to ensure it's not increasing.
You should check all of your piping as a first step to make sure you don't have a leak somewhere. That's the most frequent cause of low boost on an otherwise stock (or stage 1) car. If you can do a pressure test instead of just relying on a visual/mechanical inspection that would be even better, but start by checking all of your pipes and connections to ensure they're tight and you don't have any holes.
Scott
Thanks it has 88k miles on it. i have been looking at all of the hoses and pipes and tested the wastegate and swaped my boost controler with a use for a test and reverted back to stock and still have 7psi this has to be a small problem it runs to good.I allmost for got i removed my blow off valve and put the stock one back on.
You said it was all stock except stage 1 now you're saying there was a BOV and MBC? Those mods aren't supported by a stage 1 tune. A BOV unless a recirculating one should never be used. What kind of BOV did you have on there? The MBC needs to be tuned for, and also shouldn't be used on the car anyway unless you're way farther along in your mod path.
Obviously there's a lot more to your story you're not telling so how about you start over and tell the truth on what mods the car has had and how this problem started and when?
Scott
Inspector Scott is on the case!
- William
Thanks i got my car fixed it was in safe mode and now its running Great i reset my computer to get it out of safe mode i must have got 87 octane by mistake my bad.
