Gas efficiency and RPM
Results 1 to 15 of 19
This is a discussion on Gas efficiency and RPM within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; What is the best RPM to cruise at in order to maximize gas mileage?...
    Registered User younoleit's Avatar
    May 2012
    Dec 2011
    ontario
    personal experience... 2900-3100 is what i always cruise at gives me the best gas mileagefor the speeds i drive in which is around 120km/h. just try to stay outve boost
    May 2012
    But the manual suggests a shift point of 45 mph, which is slightly less than 2k RPM I think.
  5. #4
    Jan 2005
    Canada B.C.
    The lower the better...
    '02 WRX 4EAT, 311,000KMs/194,500Miles, Sold. Best car I ever had. '09 STi stage 1, hope this one will be good too...
  6. #5
    May 2012
    Quote Originally Posted by wrxdrvr View Post
    But past a certain point the engine can't make enough torque to be efficient, so what point is that?
  7. #6
    The Member michaelwfox's Avatar
    Nov 2011
    North GA
    I shift at 2.5k and cruise on the highway at 65mph (speed limit here is 55 anyway lol). I'm averaging 24-27 mpg.
    Not that mpg even matters
    My "Build" Thread!
    2015 VW GTI
    2006 WRX TR - SOLD
    Hawk-Eye Alliance #1856...ssshhh don't tell anyone!
  8. #7
    Jan 2005
    Canada B.C.
    Quote Originally Posted by younoleit View Post
    I didn't say to lug it, I suggested to keep the RPMs as low as practically possible to get where you are going, and you will get the best MPG that you can that way...
  9. #8
    Registered User jimbo058's Avatar
    Apr 2010
    Colorado Springs, Colorado
    I shift at 3,000, and then into 5th at 50mph unless going uphill, then I wait 'til 55 mph. I have been getting 28.5mpg with 50/50 city/hiway, so it seems to be working pretty well on my '09. I do romp on it several times a day, up on-ramps and to get by the occasional ****head, just to keep everything in working order !
  10. #9
    Registered User poly_poly-man's Avatar
    Feb 2010
    Rochester Institvte of Technorcery
    As low as possible is correct.
    There's basically a BSFC - an (almost) linear correlation between the BHP output of your engine and the fuel consumption, for certain ranges (think CL). To go a certain speed, you need a certain amount of torque. Since torque * rpm * (arbitrary constant) = HP, the lower your RPM for that particular torque, the better.
    The situation only gets worse - higher speeds get exponentially worse in terms of wind drag (increasing torque required), and higher engine speeds could start dragging you into OL fueling, and could definitely target richer cells on your fueling map.
    Basically, keep it below 70 in 5th gear (with the ratios I'm used to), and if the next highest gear will let you sit around ~2k or above, shift.
    My big thread: The Used WRX Buying Checklist - Please Contribute!
    My current car: 2002 WRB WRX Wagon.
    Mods: GM BCS, Carberry SD rom, uppipe, AEM UEGO, Klunk Killer, F+R shifter bushings, head unit
  11. #10
    Apr 2007
    8000' up in Colorado
    How hard you're pressing the gas matter more than your RPM. Hammering on the pedal at 2k RPM will burn a lot more fuel than coasting at 5k RPM.
    I've done a lot of comparisons in different cars and regardless of the car/engine type RPM matters much less than how hard you hit the throttle.
    Along the same lines, turbos burn gas much more quickly at high RPM than naturally aspirated motors, so staying out of boost also saves gas. You can stay out of boost by staying at low RPM or by simply not hitting the gas hard.
    And of course the faster the engine turns the more gas it burns versus lower RPM, but throttle pressure plays much more into the mileage as stated above.
    Scott
  12. #11
    Apr 2012
    Northern California
    I shift just above 2k around town. I average 24+ mpg city all day. On the freeway, I suggest keeping it right at the speed limit, if not lower if you want the best mpg, that's pretty much common sense.
  13. #12
    May 2012
    Thank you everyone for the input.
  14. #13
            MainFrame's Avatar
    Austin, TX
    ^this.. load and throttle opening angle are far greater contributing factors to mpg than rpm.
  15. #14
    Jan 2005
    Canada B.C.
    You are better off (for higher MPG) in a gear that makes the engine work a bit at a lower RPM (not lugging the engine), than higher RPMs, almost always...
  16. #15
    Feb 2010
    load clearly - I mean, that's just a few multiplications away from being injector duty cycle :P
    And no, is the cruising type situation I'm talking about (same speed, same conditions, going one constant speed, or for a particular amount of torque required), the 2k situation will, 100% of the time, be better on gas than the 5k situation, even if you're talking a steep uphill which requires WOT at 2k.
    Now acceleration is a different matter altogether.
