.5 bar 7psi ? What is wrong
Results 1 to 11 of 11
This is a discussion on .5 bar 7psi ? What is wrong within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; So u have a stock 2002 wrx wagon just installed a oe boost guage and I'm only showing .5 bar ...
    Registered User Deciphe's Avatar
    Apr 2012
    So u have a stock 2002 wrx wagon just installed a oe boost guage and I'm only showing .5 bar I thought the stock was around 13? Any ideas on what to check I have no cels and it runs fine. Thanks for any help
    Jan 2005
    Eh, whaaaaa?
    The OE gauge reads in MPa, not bar. If you're reading .05 MPa, then you're getting 7.25 psi, which yes is a problem. You should be just under .1 MPa on that gauge at stock.
    To verify what the car is reading, you need to do some datalogging. The results you're seeing could be a result of a botched install, and I'm betting on it being just that.
    Cody
    Oct 2011
    Santa Ana, CA
    ^do that plus check the restrictor pill assembly.
    Does the car pull as it should?
    Sent from my DROID2 Global using Tapatalk 2
    Apr 2012
    My install cannot be to botched as I'm not a stranger auto/ mech world I have it installed exactly as instructions and tapped into tech bov line. There isn't really anything I can botch and it reads 0 Ofd and -.5 at idle all correct except the boost is low
    Apr 2012
    I am not sure if it pulls as it should I hadn't driven another this is my first wrx
    Oct 2011
    Santa Ana, CA
    On a stock wrx 2 liter. Get started in first, clutch fully engage wot up to 6.5k you should feel your head getting pinned to the seat a bit. thats without boost. Then shift to second, wot up to 6.5k should produce some boost, certainly more than .5. Again, head still getting pinned feeling.
    Don't do that too much until you're sure nothings wrong.
    A bad pill restrictor assembly is a common cause for this problem. And it won't pull if that's the cause.
    Sorry for being wordy.dragged to the mall and I'm bored. And i had the same problem. auto zone didn't have the right size hose. OEM assembly was the only fix
            MainFrame's Avatar
    Austin, TX
    For a stock car 7psi boost sounds about right for 1st gear.. how are you doing your pulls?
    Apr 2012
    Any gear wot max 7 have found that I think my bcs is not working
            MainFrame's Avatar
    Austin, TX
    That'll do it every time. Just so you know, anything other than the OEM BCS will require a retune.
    Apr 2012
    Ya I've tried the green connector test mode and of everything that clicks or runs the bcs does nothing. I may have one coming from a 07
    Apr 2012
    Anyone have a bcs many after upgrade?
