Just out of curiousity what were you playing with those bolts for?
This is a discussion on STi has another problem, I expected it. within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; So I brought my car to the dealership today, for an oil change. For the first time, they wrote to ...
So I brought my car to the dealership today, for an oil change. For the first time, they wrote to come back in 3500 miles rather then 7,500. So I figure 'This should go smooth as hell since I was just there 3k miles ago, and it's the first time they wrote down the CORRECT oil change interval. But nope. Turns out, 1 bolt on each side of the rear axle is stripped.... How does this make any sense? I mean, I don't know much about cars or engineering, but I'm shocked that they would use weak enough metal that I had no idea the bolt was even going on ****-eyed. It screwed right on perfectly, which makes me wonder if the thread had gotten stripped before that and it was just following its own pattern?
I got this car, and yes I admit I beat on it pretty hard because I didn't know much about cars and I treated it like Subaru advertised it. It started to get problems, and I quickly was slapped into shape and started treating the car right, with much respect and knowing that How I treated it was how it was going to treat me in return. I now treat the car with respect, no longer bring it onto grass fields or gravel paths, but stuff still seems to be breaking and going wrong. Now that I think about it, those getting stripped had nothing to do with driving, would have just been me rushing to screw the bolt on or whatever, but I really want this car to last me a good 6-7 years, and I do not want to be constantly replacing parts. When I get the car back tomorrow, I'm crawling up under it, completely cleaning the underneath of it, then treating it like a 1 mil show car
Zach
Teh Intern @ WTF Tuning, LLC
2009 WRB Subaru Wrx Sedan: WTF Tuning Stg2
Stink eye Mob #287
N.E.R.D. #43252003274489856000 (the total number of configurations of the Rubik cube)
"It's not turbo-lag, it's foreplay"
The only reason to remove these bolts are to rebuild the Diff or install a larger rear diff cover.
I don't get it.
Btw, it's made of aluminum. It does than when you're doing it wrong.
Zach
Stink eye Mob #287
Are you sure you aren't talking about the wheel hub bolts?
-Tony
2011 WRX WRB Stage2
2012 FXT DGM
The Big 2011/2012 Mod Thread
Isaac -- 2003 WRX sedan Stg II
He who shall be last, shall be sideways and smiling... - Jeremy Clarkson
I feel like this dealership is trying to take advantage of you or something.
It's always something different from them man.
Did you happen to use a torque wrench to torque them correctly when installing the wheels(should be ~72.5ft/lbs)? It's very easy to over torque those nuts/bolts with a decent size breaker bar. People tend to over torque them when not using a torque wrench to make sure not to have the wheels fly off when driving. Over torquing them is bad for the bolts/nuts(as you just found out) and wheels especially if you have the expensive BBS wheels.
This is the first time I've heard of the bolt stripping. They usually break off before stripping.
Maybe its a little late now, but I would highly recommend torque wrench in the future when you decide to do work yourself.
2011 WRX Limited Spark Silver (5 Door)
